Which lithium battery?
Gary_M
So, finally going to install a leisure battery after talking about it and then doing nothing. Main reason is I want a diesel heater in the next few months.
Anyway, I’m going to opt for a Renogy DCC50S and limit the charging current to 30A. I was eying up a 105Ah Fogstar lithium battery but they’re now out of stock. How do they measure up to the Renogy 100Ah battery? Would you wait for the Fogstar?
Thanks for any advice.
Umm.....
Renogy do a larger ah battery. That fits I. The same physical space....
Same space as a 100/105Ah? I’m looking to locate it under the passenger swivel with the DC-DC. Be good if I could squeeze the 12v fuse box under there too..
I have the Renogy. It works fine. I had a little issue (resolved on here) and there is zero help from Renogy.
I’ve fitted a Fogstar into a friend’s van and it seems more compact. The app is better in my opinion and the bottom line is that it’s UK supplied with a company that you can contact.
My next battery will be Fogstar.
Thanks, I’ve opted for and ordered a Fogstar Drift 105Ah battery
Wise move re the Fogstar. I have had two Renogy 50aH Life04 batteries that I have had to split open to reset the bms because cell groups have gone out of balance. I am now waiting for a balancing board arriving from Amazon to hopefully prevent voltage levels going down on any of the 4S arrays.
  • Sad
I guess Renogy (which I hate, as I refused a 20A charger - ordered 40A the same day - and got 75 quids refunded after 6 months) or ecoworthy are general cheap options. Seat base 200 ah thingy (fogstar, roamer) + newest greatest victron dc to dc is the premium choice.
