Which module does this error relate to? P00AF00: Turbocharger/Supercharger Boost Control "A" Module, Performance
Bert69
Or as VCDS reports "16408 - Actuator Module for Turbocharger 1 ".
Which module is actually being referred to?
I have read though the documentation and can see 2 turbos, several actuators and 3 control valves.
It looks like the N75 valve controls the adjustable guide vanes on the high pressure turbo and the turbine bypass flap
and conversely N529 controls them also also as the vacuum lines are interconnected.
Valve N274 solely controls the wastegate.
Does anyone have any details regarding this error?
Thanks.
Have you seen this thread
@Deansie is working on all possible components causing the P00AF: N75 or the actuator or sticky vanes.
Also the test below is useful to observe how the chain of the components perform as the test commands the actuator to do full swing at full speed several times.
