When we used RIB (scopema same compamy) and the shim bars they still caught the handbrake cover just. The lever to rotate is on the side so seat base trim needs to be cut if you want to go fully low. Sportscraft, Reimo or similar have lever at front so no seat panel trimming needed. The handbrake will need lowering with these types. You could use lowering bracket but we dont like this as it is functional, not pretty and you cant use factory plastics.Thanks Eclipse, so if I have my drivers seat at the highest setting with the included spacers/shims will it still rub against the handbrake? Looks like the scopeama/Kiravans/Rib will be the way to go?
Hi Martin, i meant the lowering bracket is fine and functional and yes you can get covers but we try to leep everything looking OEM using original plastics, not using double width aftermarket plastics for example. Nothing wrong with this but we have a different approach. CheersAs far as i am aware @Badger , although i could easily be wrong,all of the swivels you have mentioned will need the handbrake lowered to swivel the seats properly. There are options to tidy the plastics up. Not sure what you mean by messing around with factory adjustments? If its just the handbrake cable you mean,it just gets tightened up. @Eclipse Campers seems to have a different solution to a lowering bracket but not sure why a bracket is not functional,ours works fine although we did fit a stronger one than the one that came with the Sportscraft swivels which is a bit flimsy,View attachment 91885hope you find the solution you want
Thank you BenP makes sense, can I ask why you need shims for the passenger side? Are these the same scopema swivels Kiravans sell? Would you be able to post up a link if not please?
I have a sportscraft swivel on my passenger seat and can’t fault it.Hi guys after just a passenger swivel for my van.
Do you need offset because of the armrests for the passenger seats or not?
And do all the swivels require trimming of the plastic parts?
I have the bottom plastic facia that you can pop on and off with some plugs and want that to be able to keep that there. Any advice? See pic.
Pivot is central not offset.
To spin it you need to lever the seat up and wind the back of the seat to a vertical position but it spins fine and doesn’t catch the arms.
As for the base piece with your sockets in, you’ll need to trim the top section that goes under the Seat. Won’t affect the plugs at all.
I trimmed mine then used a few strips of Velcro to secure it.
I can’t comment on other models but in my experience Sport craft will suit your needs perfectly.
Thanks mate just what I needed to know. Have you had any issues with rocking or creaking?
Its this one isn't it?
Swivel Seat Base (Passenger) VW T5 2003–2015 VW T6 2015–2024
TUV-approvedWeight: 15kgHole Centres: 395mmx384mmHeight: 27mmwww.justkampers.com
I’ve got this one, from these people:
SPORTSCRAFT VW Transporter T5/T6 PassSingle Seat Swivel
SPORTSCRAFT VW Transporter T5/T6 swivels are a great addition to your vehicle which allow you to rotate your seat to face the rear of the vehicle.www.jennings-seats.co.uk
They do one with the nut on the top if you have stuff under the Seat. Raises the Seat slightly higher.
Zero creaking. It doesn’t “rock” rather flexes when no one is sat in it.
Misses says she can feel it flexing more than it it did before fitting but it’s not an issue.
If it had creaked or vibrates causing a distraction I’d have taken it straight out as for 95% of its live it’s just me in the van driving it.
For the money you can’t go wrong.
New to T6 and I want to fit a passenger swivel; I'm concerned about the airbag electrics...( never had em on my old T3) does disconnecting the battery solve all issues or do things need resetting when the battery is reconnected? What is 'caristaapp'?"Heated seats a doddle nice big hole in center of swivel base and wee connector under the seat. If if was going again I would disconnect the battery first, I have airbags in my seat and got airbag warning msg when I plugged them back in. Glad I got caristaapp
Kev
