@Mavis628 is not a VIP member
You only need to be a VIP member to start a for sale thread anyone can see and reply to the posts.@Mavis628 is not a VIP member
Well @Mavis628 easy thenYou only need to be a VIP member to post in the forum. You can still see the posts.![]()
If the single is similar to the double, the whole box swivels, so you could put a battery inside the box, but you'd need to be very careful with trapped and twisted cables to avoid shorts. The pivot is at floor level.Chaps anyone confirm if the Kiravans single passenger swivel will fit with a factory fitted leisure battery under the seat?
By coincidence I was talking to my lad this morning about the very same thing (he has a Kiravans double-swivel), pondering methods of disconnecting the battery whilst actually doing the swivel operation, then reconnecting once its done - using a duplicated connector front and back. But its a faff and a potential for shorts... so I dunno yet. Probably not
Phil
I've got two Sportscraft that I've now taken out. They rattle, rock , squeak. Just too much bare metal to bare metal. They won't be re fitted.
That's really odd, my two are rock solid, no movement at all. It's almost impossible for them to rock when they are located in the straight-ahead position. I wonder if they made some modifications to the design along the way?
@garybo85 I have a kiravans offset swivel on my passenger seat, and hate it. It’ll soon be going in the bin.I've just got a kiravan offset swivel drivers seat for my T6 kombi
and after much excitement waiting for it to arrive im extremely disappointed.
when turning the chair round to face the rear, the chair does not lock into any position and swings freely. the only thing stopping it going a full 360 is the handle for the locking catch.
Are all offset swivels like this or has this one been manufactured incorrectly. it looks like the lug has been attach a couple inches away from the catch.
I can not see any other way to fit it. everyone reviews of this swivels sound better. but I can not see how it can be fitted incorrectly and most of the problems are to do with the swivel.
it did also come with missing bolts so I wondering if they have been careless with this manufacture/order.
also when lowering the seat in the the driving position the swivel handle digs into the seats original plastic? does this all have to come off or be cut?
The swivel frame rubs along the top of the handbrake and i've heard this do not require the handbrake to be moved .
I’ll give it a whirl (pun intended, swivel/ whirl, get it?). Albeit I crammed it full of bearing grease which did nowt, but all up for giving an alternative a shot.I also have the Scopema (Kiravans) offset swivel and no, they do not lock when facing backwards.
DaveyB, mine creaked like crazy as soon as they were fitted and I was extremely disappointed as the noise drove me insane, however, I contacted Banwy who supplied them, and they recommended applying silicon spray (I went for the WD40 variety in the yellow can) to the hour-glass shaped guides between each plate. Problem COMPLETELY solved. No creaking when empty or with a passenger.
Give that a try before chucking them![]()
HiDoes the Sportscraft lock in any position other than facing forward?
Just trying to decide which to go for.
Also, does the Sportscraft require any trimming of the plastic seat trims?
