How many miles were driven on the oil? How old was the oil (months)?oil analysis showing 277ppm of iron
The van has gone from using virtually no oil to1 litre per 1000 miles. Current oil has done 6000 miles at 8 months old.How many miles were driven on the oil? How old was the oil (months)?
Is the oil different from the last time? Same weight, same make etc?The van has gone from using virtually no oil to1 litre per 1000 miles. Current oil has done 6000 miles at 8 months old.
I have not yet done a compression test but there would not necessarily be a high aluminium content if there are worn or scored bores.If you had worn bores you would also have high aluminium content on the oil analysis (pistons) and reduced cylinder pressure / high blow-by rate.
Is that the case?
Of course, always.Is the oil different from the last time? Same weight, same make etc?
No, there is no aluminium in the oil analysis.Is it using any coolant? I’ve read the egr cooler can leak coolant into the combustion side of the engine causing lots of damage.
Yes, there was a case on the Forum a few days back, a European member.question is has anyone had their engine replaced and whether they did this as a result of high oil consumption.
Hello,
I Up this thread, because I have some informations about oil consumption on the 204 engine.
Just come back from my VW dealer for a oil weighing because of lot of oil consuption on my 2017 T6 204ps.
The van had 133k km, from 04-2017, the weighing give our 1,2l of oil consuption on 1000km. (had done on high load^^)
It's the workshop chief of the dealership who tell me to do the weighing because there is some faulty engine for the 2016/2017 204ps...
The service note frome VW Deutschland is know since approx December 2020, the workshop chief had found faulty engine just before this date and had open an engine.
Since this date, he swap one or two 204ps engine every month on his workshop !
For what he know and had found, it's a piston problem, who start to melt... and newer engine had renforced pistons.
Therefore, it's not the same pb than the 180ps T5 engine.
Now he will tell VW DE for engine swap price participation, normally, 100% of parts will be supported, and at least 50% of labour. (100% of labour was supported on the firsts swap he done, but since this summer, he no longer has that...)
For the moment, I just found some informations about this engine swap on TX-board forum (De) Ölverbrauch T6 150 KW
But no others informations about it elsewhere...
I'm interested if other member has this problem and engine swaped on you T6 204 ?
I will give you some more informations when I will have it.
(Sorry for my not perfect english..)
Flavien
Thanks, that may be of some interest, cheers.Yes, there was a case on the Forum a few days back, a European member.
Unfortunately VW UK is a different entity, always right and full of sh£t.Thanks, that may be of some interest, cheers.
I bought my van with 38K miles on it, I check the oil every week and change it after no more than 10K miles. I've got 60K miles on now, it's never needed a top up.How often do you check and top up your oil? I have a T6.1 204 DSG 6 months old with 6k miles done and just realised I haven’t checked it.
