Windscreen washer low-level indication
Yes but it’s an integral part of the bottle so you have to change the whole thing
Thanks for reply. How much of a ball ache to replace the bottle and add wiring?
I enabled the warning light option through Obd eleven and the low washer flyid bulb lit up.
Yahoo...until I realised the washer bottle was almost full.
It’s a bumper off job, the sensor has a two pin connector and needs a cable run back to cluster (other side goes to ground)
Hmm that work vs carrying around a bottle of screenwash :thumbsdown:. Hardly the point for most upgrades. I think worth doing just because it can be done.
So VW go to bother of making another washer bottle with switch and one without.. Not just a boss that needs opening and plug adding?
Does anyone have the part number required for the new bottle, seals, connector plug and a blank for the headlight washer outlet please?
I would also would like to retrofit heated washer jets? has this been done?
