@Dieseldonkey Cheers! The Devonports will be coming off in spring as I have a bigger set of 'summer' wheels so hopefully should get a few years out of the Nokians given that I only do 10k a year
I guess when you pick a tyre it's all about compromise; If you go off road in harsh conditions then I'm sure the BFG KO2 AT will be better in the off road bit and more robust regarding rocks etc; but they will be more noisy/less economical/poorer wet braking/potentially poorer in ice as it's a summer rubber compound and not an all season/winter rubber compound/poorer dry handling&braking. But they look really Good imoI am now riding the Nokian Weatherproof, I find myself very well but I will also buy the Bf Goodrich A / T .., they are also M + S and on the mud / dirt roads are unsurpassed ....
Really pleased you like them. We have 25k miles on ours Vel now, we are doing many more miles than I thought (it is so nice to drive, we choose to use it over the car for most journeys....)
I think on current form we will get upto 40k miles out of them if we change at 3mm tread depth
I spent all day ferrying staff around in ours today, it is brilliant in the snow without a doubt, even been pulling cars out. Snow isn't that deep at our house, but within 1 mile ditches have been completely filled with blown snow, running adjacent to roads, and yes there are now cars in the ditches; 12" of snow on many roads with some "A"roads closed.
Got a busy night picking up and dropping off.
I must say yours does look pretty with a layer of snow on it.
Have you had it washed @chriscroft ,it looks shinyI think your van isn about 1990mm high - standard spec; +12mm for larger tyres = 2000mm(ish)
I'm 20mm drop; 30mm would be fine.
The general wisdom of this forum seems to be the Bilstein coil overs, and if you want to control roll in corners add the H&R thicker stiffer anti-roll bar.
View attachment 18810 View attachment 18811 View attachment 18813
the last image is with a standard van tyre which these second hand Devonports came with.
here is a link to my wheels on this forum
Devonport colour change & Tweaks
stock photos those are....,no more washes till Spring TimeHave you had it washed @chriscroft ,it looks shiny
Legend. Thanks for this. Looking at putting on the H&R 25mm spacers you mentioned in the spacer thread also. Can't wait!
1). yep they will fit perfectly, but you really should consider wheel spacers; hubcentric; TUV approved; HR+ are some of the best but there are others; consider 25mm spacers on all 4 wheels, you could go slightly larger on the rear wheels say 35mm each side if you are really going for it.... Carlos Fandango .....Right... I’ve collected the van! Buzzing.
The only thing is, it came with the 215/60/17 Conti Cargo’s... I had assumed it had standard 235/55/60. But it seems from other threads there is no standard!
She looks like she’s been skipping leg day at the gym. Very skinny. Disappointing for a T32. I have some questions if someone would oblige please?
1. I’m now unsure wether it will fit the Nokian 235/60/17’s? Does it need to be wider alloy?
2. How would you get around having a really wide tyre, say 245+ Thinking you could decrease the alloy size (maybe 15 or 16) and go for an oversized/off-road look.
3. How does going for the above effect ride, speedo and fuel consumption?
2) I think all T32 have 17" wheels standard, if so 17" is your minimum wheel diameter to fit over your brakes callipers. If you want the off-road look stick with the Devonports and consider 255/55/18 (wheel change) tyres 7.5% increase in gearing, and 25mm increase in radius = 25mm lift. or 235/65/17 Cooper Discoverer AT3(same wheels) which gives you the loading for a T32 (not sure that the 235/60/17 Coopers AT3 have enough loading for you - need to check). 245 width is find with wheel spacers so long as the aspect ratio/wheel diameter is not too oversized
3) Speedo is 4% out with 235/60/17 & 7.5% out with 255/55/18 to 235/65/17's. That means you are actually going faster than the speedo shows. In actual fact the 235/60/17 makes the speedo spot on, because they generally over register.
Fuel consumption wise, in theory y0u just change gear at a slightly different revs to counter the change in gearing, in and my experience oversizing wheels does cost you a mpg or so, but nothing excessive. if you switch to a fairly aggressive tread that might cost you 2mpg on top.
Love the van![]()
What's first on your shopping list?Now it’s here I’m looking forward to getting it kitted our the way I want it. Got some things in order. Thanks again for your help and time replying.![]()
All sounds good to me; I think powder coating your wheels against a silver body will be a really nice mod.
Another expensive option, but one which really works for us is the overnight heater combined with a leisure/second battery, a lovely luxury for how we use our van.
