FOGSTAR Drift 12v 230Ah Seatbase battery -- "How I Done It" --
check out the latest @Dellmassive Lifepo4 battery install & test
yep I've done it again . . . .
and with a wicked BT APP,
Built in HEATER for SubZero Charging,
200A/200A - charge & discharge rates (400A peak)
2944Wh of power
10 years warranty
Active cell balancer (seperate box)
whats not to like.?
lets take a look at the spec. . .
If you're looking for a more compact option to power your campervan, look no further than the Seat Base 12.8v 230Ah Lithium Leisure Battery. This genius Seat Base battery is designed to fit snugly under the base of your swivel seat – convenient and space-saving.
The dimensions of our Drift Seat Base is 275 x 315 x 187.5 - making it one of the most compact variations of Seat Base Lithium Leisure Battery on the UK market.
Manufactured using Grade A EVE LiFePO4 Lithium cells, high discharge JBD BMS, built in Bluetooth and Heating - our Lithium Leisure Battery collection offers everything you’d expect in a premium product.
All batteries come with our Fogstar Drift App, enabling you to access real-time data about your Lithium Leisure Battery at all times. The Fogstar Drift app is free to download on both Android and iOS.
The most popular Lithium battery brand on the UK market, our Drift range offers phenomenal cycle life (>4000 cycles), low environmental impact, Bluetooth - and a superb 10 year warranty.
You'll now find an on/off switch which allows you to put the battery in hibernation mode without connecting to the App.
You will also find an input for the new Fogstar Drift (JK) 2A Active Balancer which you can plug-into your battery (if required).
However, because our Drift batteries contain matched and balanced Grade A EVE cells, you should not have to use an Active Balancer often, if at all. We recommend plugging the device in every three to six months, for two to three cycles (depending upon levels of cell disparity - if any).
Seat Base Lithium Leisure Battery - Fogstar Drift 12v 230Ah
Fogstar Drift
1 review
£819.99
Seat Base 12v 230Ah (with Active Balancer)
12v 230Ah Seat Base
1
Quantity
Add to Basket
Share this:
Share on Facebook Tweet on Twitter Share on LinkedIn Pin on Pinterest
DELIVERY INFORMATION
Our team will be in touch, shortly after you've placed your order to arrange a suitable day and time for delivery.
Want to learn more about Fogstar Drift Leisure Batteries? Check out our blog and find out how our Worcestershire-based team went about creating the UK's best value LiFePO4 Leisure Battery brand.
SPECIFICATIONS
Nominal Capacity 230Ah
Nominal Voltage 12V
Recommended Charge Voltage 14.4V
Max Cont. Discharge 200A
Dimensions 275 x 187.5 x 315
Weight 25Kg
Fogstar Drift terminals: M8 in size, 1.25 pitch, 12mm. All of our Drift leisure batteries come with M8 bolts and terminal posts as standard.
Ideal for use with Inverters up to 2500W.
WARRANTY
Fogstar offers a 10 year warranty on all Fogstar Drift Leisure batteries.
Warranties only apply to the original owner and are non-transferrable.
Fogstar will verify your purchase prior to processing any warranty claims or returns.
If it is determined that the product is faulty, we will ship a new product to you immediately, you will only be asked to cover the cost of the shipping.
Our warranty does not cover items that have been damaged due to gross negligence, normal wear and tear, damage due to accident or collision, abuse or incorrect installation.
that's the official blurb,
lets take a look at it. .
i went for the option with the additional active balancer,
the box is well packaged . . . it needs to be, these are HEAVEY - 25Kg !!
you get a few nice goodies in the box,
window cling sticker,
Fogstar airfreshner,
QC check sheet,
4x mounting brackets and screws,
the case disign is very similar to others weve seen,
but this time with the addition of a SOFT OFF SWITCH and a covered port for the ACTIVE balancer to connect in,
the side handles are very nicely designed, all metal and black,
though pull out to the side, so not so useful if the battery is in a tight space, - a prime example was just getting the battery out the packaging, there was no way to open the handles in the box,
not a problem as i could tip the box up and ease out the battery.
but will come across this again later when we fit the battery ion the vans seat base.
the screen printing is nice and offers the basics with a QR code for downloading the APP and install guide.
the battery terminal covers are a standard thing for these M8 bolt down battery terminals.
though im not so sure about the Black anodised Bolts - sure they look nice, but are they the best for electrical conductivity and low resistance?
another small point is that these bolts are fairly short,
if you have numerous cable ring terminals to attach to the battery you will soon run out of threads - and not enough screwed into the termianl itself.
it would be nice for Fogstar to offer both sort & long bolts to suit most users install requirments.
i had to swap out the POS terminal bolt as it was too short for the three ring terminals i had on the POS, but the NEG bolt was fine as i only had one cable that goes to the shunt.
just saying - there room for improvement.
the bold down brackets are a very nice feature and shows good engineering thinking.
these are very heavy, so if not held down properly they will go flying in the event of an accident . . .
i have mine fitted in the seat base, so its not going nowhere,
and with the carpeted floor i had nowhere to bolt down to. . . . biut if i was fitting in the rear then id defo screw down to something.
Seat Base Lithium Leisure Battery - Fogstar Drift 12v 230AhSeat Base 12v 230Ah (with Active Balancer)
Seat Base Lithium Leisure Battery 230ah | Grade A EVE LiFePO4 cells, JBD BMS, Bluetooth & Heating. Just £799.99 with a 10 year warranty.
www.fogstar.co.uk
2944Wh of power
10 years warranty
whats not to like.?
Fogstar Drift
1 review
£819.99
12v 230Ah Seat Base
1
Quantity
Add to Basket
Share this:
SPECIFICATIONS
Nominal Voltage 12V
Weight 25Kg
WARRANTY
QC check sheet,
