Hi All,
Hoping you can shed some light on a situation i currently have with my T6 105.
Day to day the van runs fine, no issues with DPF regens etc, engine light on due to egr low flow but no other codes stored currently. After about 90 miles sat at 60 with cruise on the ad-blue range went from 3000 miles to 650 with the spanner - Drove around for the next couple days with the light on and range reducing to 550 - then had to head back up M6 for the return 90 miles but this time gave it a solid kicking for most of the journey and as I joined the A69 the fault appeared to clear and i was back to 3000 miles range.
This same thing happened last year on the way to Gatwick and again cleared on the run back home so a little confusing as it never occurs on shorter journeys.
Has anyone else experienced this? Could it be related to the egr low flow? Have spoken to a garage who suguested blanking the egr and coding it out an that the ad-blue could also be deactivated but not sure where I would stand MOT wise etc? Also been suguested that i try and ad-blue additive as there may be crystalised ad-blue on the level sensor thats causing a spurious fault.
