Comfester cf100 225/55/18. Amazing grip, slightly noisy but that's what the radio is for right fit brill, love em!
These are so much a Chinese BF Goodrich KO2 knock-off :rofl: Not sure if that's a good thing or not! They're the Comforser Cf1100. They're about half the price of a KO2, £110 for a 225/65R17 Vs £220 for a KO2 of the same size. Speed and load rated too, 102T for the 225/65.
No idea, but I think they have been amazing for me so far, and I use the camper everyday of the week so
You're quite right. Perhaps ~60 mph average could improve things. Those with manual gearboxes might also be able to get even better results.
Well I sit at 65 when on the motorway, 5 speed manual, currently driving from Lancashire to great yarmouth twice a week (300miles) and using 1/3 of tank.
Looks good! I’m buying a panel van like this and am starting to look at wheels! Trying to get my head around offset ( ET ) any advice?
Hi.
Took me a while to understand ET too.
My front tyres rubbed very slightly on the inner wheel arch liners on full lock. I needed to reduce the ET50 of my wheels slightly, using 5mm spacers.
At the new ET45 equivalent they don’t rub now and pass the UK MoT test!
Try this;
“Offset is stamped on a wheel as an ET value, which refers to the German phrase “Einpress Tiefe.” ET indicates the distance between the mounting surface and the geometric centre of the wheel (the symmetry axle), usually expressed in millimetres. When the ET value decreases, the alloy wheels will protrude further out.”
Hope this helps
Andy
Hi, I'm thinking of ordering the Tomohawk Kato alloys for my T6 but unsure what tyres to go for. Rogue Alloys recommend Grabber AT, the fitter recommends Geolander AT but I notice many people on here favour the Falken Wildpeak. I'm thinking tyre size of 235,65,17. Does anyone have any opinions of which is the best tyre for these alloys and any pictures fitted would be amazing?:)
Hersteller Volkwagon
Fahrzeugtyp
Fahrzeugmodell T6.1 T32 LWB
Höchstgeschwindigkeit 182 km/h (inkl. gesetzlicher Toleranz)
Vorderachse Hinterachse
max. Sturz <= 2,00 Grad <= 2,00 Grad
max. zulässige Achslast 1040 kg 960 kg
Reifengrösse(n) 235/65R17 108H XL AT3WA 235/65R17 108H XL AT3WA
Profilvariante WILDPEAK A/T AT3WA WILDPEAK A/T AT3WA
zul. Felgengrössen 6,5 - 8,5J 6,5 - 8,5J
Abrollumfang 2222,0 mm 2222,0 mm
Kaltluftdrücke (Volllast) 2,0 bar 2,0 bar
Es ist sicherzustellen, dass der Fahrzeughalter zu jeder von ihm
have just checked the values again and can confirm that they are correct.
We always calculate the filling pressures individually based on the actual axle loads, whereas in general the maximum permissible filling pressure is often applied, completely independent of the actual axle load.
