Now that ForumFest 2020 is over i thought i would share the Power data . .
After the huge success of the recent Brook Meadow weekend at Sibbertoft in Leicestershire, I've decided to do another one on the cancelled Busfest weekend, at the same location. This will initially be open to 40 members on the pretence that I might add more if demand calls for it. The...
www.t6forum.com
The setup was the Lifepo4 battery box i made over here >
12v Lithium Leisure Battery Box 138Ah 1766Wh -- How I Done It --
we had two compressor fridges running on 240v via a small 300w inverter . . . . (work more efficiently this way in my testing) plus other USB stuff and 12v LED lighting in the Tent and awning . . .
layout wise . . .
we had the Battery box outside . . .
This is the BM2 readout for the weekend, starting with a full charge the day before on the Victron 12/30/1 charger . . .
below is the first day . . .
you can see the Valence Lifepo4 13.5v rest voltage . . . . then plugging in the fridges at 1830hrs . . .
the next day i managed to get some solar layed out . .
you can see the dips in the graph which is the draw from the compressor fridges cycling on/off . . .
and the rise in voltage from solar from about 9am . . . (overcast day, but bright - no direct sun)
the same continues the next day . . . . but this time with direct some sun 1100 to 14oohrs ish . . .
yopu can see the difference in the charge from tghe solar mppt on a sunny day vs a cloudy day. . . .
but its still good enough to run all the kit, plus recharge in the day time.
next up is the last day and breakdown . . .
you can see it was a sunny day - 1200hrs onwards . .
the solar and frisges were disconnected at 15oohrs ish for the pack down . . .
and the next day . . .
Dellmassive`s -- "how I Done It" -- Thread
