Yes, please. More data = better data. Thanks.Do you still need this doing? Cheers
Ok. Will collect some and post here.Yes, please. More data = better data. Thanks.
I’ve just done two long journeys so I’ll look out the data for you. Blower was on 2 all the time as far as I can recallYes, please. More data = better data. Thanks.
@mmiAs the weather is warmer than in February and also more daylight - I'm wondering if you could do following and plot starter battery voltage (using BM2). Would appreciate if others could do the same @Ayjay @Big.mac ?
Before starting the engine set the blower speed selector to "2" and keep it there during your run. May use also settings 3 or 4 but absolutely not the setting 0 or 1. Also outdoor temperature should be above +15C.
I'm interested to see what's the lowest voltage during the runs (when engine is running - so preferred to have stop/start disabled). Mine seems never go below 13.3 Volts.
Thanks.
Thank you very much. Unless I'm mistaken on the pictures, also yours seem to charge battery at 13+ Volts when engine is running with heater blower at "2".@mmi
So here is the graphs for mine for the last few days. Only short journeys but the blower has been left on 2 throughout, AC is on and on pretty much every journey the lights were on (they are on auto but even though it is light they seem to come on early in the morning).
I have a DC-DC charger attached as well which will add some load. I can see it is working by looking at the leisure battery monitor graphs.
It won't damage the batteries - typical allowed max charge current for automotive lead acid batteries (70Ah+) is around 100 A. And yes it will "stabilize" eventually.The question is, will this damage either battery? Will it eventually drop the current enough and start charging normally?
Just remembered I took a screen shot of how it had charged once I got to the supermarket. Looks like classic absorption charge stageView attachment 80607
looking good, you done well to get an 8min slice of data, my phone always times out and disconnects before that.
id imagine that current curve will keep sloping down to around 1amp . . . so it can still take some more charge . . .
thats i only thing i wish Victron would do better and add in the data logging, the boxes can do it, just wish i dint have to my a live cobection on the phone. =[
at least the good old BM2 can fill the gap till then.
saying that if you fit a Raspery Pi and connect up yo a hotspot you can have 24/7 data logging.
see here:
Solar Sheds & Other Non-t6 Solar Projects - How We Done It -
Solar Sheds & Other Non-T6 Solar Projects - How We Done It - @Pete C requested it, so here it is . . . . . Dell, What do the batteries in your shed power ? I too have a solar powered shed - perhaps we should have a separate thread for sheds :) Pete Lets Post here any NON - T6 related ECO...www.t6forum.com
depends on the existing cable gauge and its fuse rating . . .Funnily enough earlier today I was thinking that I need a couple more USB sockets in the back of the van. Excuse the stupid question but would it be safe to just tap into the wires coming out of the back of my existing CBE (single) USB socket or CBE battery monitor (so long as the new one was fused).
