That’s good to hear you are loving it.
BognorMotors
Hi I would like to ask about DSG gear box software for the future, as my T6 Executive is on just one year old and I would be concerned about warranty issues untill this has expired. Firstly I find engine braking on the T6 to be exceptionally poor compared to any vehicle that I have driven or ridden for that matter. I use engine breaking most of the time and obviously I will chose the most appropriate gear for the maximum retardation when necessary either by the provided flappy paddles or by selecting manual control via selection on the gear lever by pulling it to the right while in drive.
1. Do any of the programs that you use provide, give greater engine breaking? I think that I saw somewhere that less engine breaking can be selected but I am only interested in a greater force of retardation. It is quite frustrating to need to use what I consider to be an excessively low gear to help or hold the vehicle down hill, only for it to runaway with the engine revs getting higher and higher anyway, on even what I would call moderate hills. Where other vehicles weather they be manual or old fashioned auto box held down manually, negotiate the exact same situations adequately well!
2. I have noticed that the mapping that is provided for DSG appears to improve the selection of gears while selecting Drive. Has any modification been applied to the sport selection?
3. Do you by any chance provide the VAG VW updates that seem to have arrived to cure the appalling and notorious pull away problems associated with the DSG or is this a Main Dealer only Fix?
Thank you.
Thank you for that information.Ok to answer your questions;
1 Yes, a better matching shifting strategy is included in our drivability upgrade solutions. Due to the increased engine speed during low/part-load operation, engine braking will be increased as well.
2 Usually the sport strategy is lowered and better matched to trailer usage. So lower engine speeds in low/part load, and better usage of the available torque during heavy load situations (trailers etc.)
3 Yes, we offer all available factory updates and our tunes are usually based on the most suitable software version (whether update or not, not in all cases are updates better )
I believe Oli has covered this before but I can't find his quote, sorry.Oli, does the TVS modification affect warranty in any way
No problem.Thanks Uk
I had mine done 2 months ago by @BognorMotors and it transformed the driving experience from irritating to what you would expect from VW. My van is two years oldGreat, will find and have a read later
Its xxxxxxx (removed by loz and forwarded as a PM)TVS improves the operation of all DSG gearboxes. DM me your postcode and I’ll find your local dealer.
