![]() | REAR - BOSCH 0 986 479 097 Brake disc Link 294x22mm, 5x120, Vented, internally vented, Coated, High-carbon |
![]() | REAR - BOSCH 0 986 494 583 Brake pad set Link Low-Metallic, incl. wear warning contact, with anti-squeak plate, with bolts/screws, with spring, with accessories |
![]() | FRONT - BOSCH 0 986 479 B88 Brake disc Link 308x30mm, 5x120, Vented, Coated, High-carbon Or could it be that I need 340? |
![]() | FRONT - BOSCH 0 986 494 107 Brake pad set Link Low-Metallic, with integrated wear sensor, with anti-squeak plate, with piston clip |
![]() | FRONT - QUICK BRAKE 109-1680 Accessory Kit, disc brake pads Link Only applies to the front brake set right? |
![]() | REAR/FRONT METZGER 11679K Bolt, brake disc Link |
![]() | MA PROFESSIONAL 20-B01 Threadlocker Link |
![]() | REAR - NEO TOOLS 11-127 Reset Tool, brake caliper piston Link I need this for driving back the rear pistons due to the handbrake mechanism etc. |
![]() | MA PROFESSIONAL 20-A10 Copper Grease Link Much appreciated! |
Silicone lube was for slide pins on my mondeo not sure if I need it on a T6. So clamping brake line is new to me. Not sure if I'm comfortable takin off brake hose though so will just try windin piston back in with master cylinder vented - if it'll wind anticlockwise. Maybe justba squeeeeeze with a ratchet clamp...I’ve just done the rears on my T30 and used my Ford Sierra wind back tool which winds in clockwise.
I clamped the rubber hose off with a plastic clamp, undone the bleed nipple then wound the piston in. This avoids any crud getting pushed back to the master cyl / abs.
I had to re-use the caliper bolts as no new ones with the pads - These have been supplied when changed on previous VW group vehicles. These needed a dab of loctite.
Rotary wire brush in the cordless drill to clean up the wheel mounting face / collar.
Not sure what the silicon spray is for? I’d avoid getting it anywhere near brakes!
Thanks for thisI recall answering much the same question a few months ago...to save me repeating myself ill copy the link, there is probably other info in the thread that will be of interest - Brake Cost Replacement
It's a good thread but am wanting recommendations on pads as am lookin on ebay and thinkin... maybe I should check in wi the lads... your link has me pondering maybe checkin halfords too thoughI recall answering much the same question a few months ago...to save me repeating myself ill copy the link, there is probably other info in the thread that will be of interest - Brake Cost Replacement
