I'll try that too.
I did ask that on 21 Dec, didn’t the garage check?I'll try that too.
Excessive crankcase pressure?
They did have a listen and seem to be baffled by it.I did ask that on 21 Dec, didn’t the garage check?
Hi NiknakAlso could you run the engine for a while and whilst it’s running undo the oil filler cap and see if there is pressure there ( there will naturally be some )
@flyingging I think the video would be far more useful with the oil filler cap removed to get some idea of the crankcase pressure. Maybe hold a piece of paper so that it gets blown by the crankcase gases.Hi Niknak
I've done a recording but file too big. Are you on WhatsApp ?
That’s what I thought, valve just contacting piston crown and lack of power. Mech‘ needs contacting alright, in the physical sense. If he didn’t get the timing correct there’s a good chance the seal replacement is a balls up as well.According to vw timing is out I advised him to contact the previous tech and speak to him regarding pay for the out come as he’s done the cam belt so god knows how bad the outcome is
Got your email with links in, i thought it was going to be audio but they are video clips and way too large to upload to the forum
You will need to upload them to youtube (or similar video hosting site) and post a link here
The vw main dealer thinks the timing belt is on wrong and the seals were fitted wrong too ! The mechanic god is in Monday. Will know more then.@flyingging I think the video would be far more useful with the oil filler cap removed to get some idea of the crankcase pressure. Maybe hold a piece of paper so that it gets blown by the crankcase gases.
That doesn’t sound like failed main bearings to me. The metallic knocking noise seems to match the reciprocation, ie pistons / valves.
The engine also seems a bit gutless, is it lacking power?
The turbocharger is responsive as the hose is swelling as engine is revved.
