So tomorrow if vw offer to fit a seal and another timing belt i have to say don't charge me if it doesn't hold ?
If it doesn't hold then the other mechanic was right but fitted the timing belt on wrong in the rush to get it out of the garage . The bad noise was only after the second attempt. It never sounded that bad before. Maybe a tiny flutter higher up the revs.
The main dealer said they'd never had a crankshaft seal leak post fitting ( But they would say that).
And if it's all fine after new seal i go back to the other mechanic and ask for a refund.
I hope it's that simple but I'm not convinced.
if it was me I would ask the VW mechanisc to take some photos of the seal and housing etc, if it shows it has been fitted incorrectly then write to the other mechanic enclosing the photos asking for a refund - always put these things in writing. It would be very difficult for him to argue he had fitted it correctly if the manufacturer says its wrong. If its been fitted correctly then why did it fail? The same with the timing belt. VW should be able to give you a written report after they have taken everything apart.
