We answered all these questions beforeSleeve at chilli
Are proper sleeve any better,
Whether the thread is on a sleeve or machined into the body of the shock itself, they still offer height adjustment, but having the thread as part of the body of the shock makes it easier to adjust.Sleeve at chilli
Comfort and handling come from the shock absorber , this is the important bit , The height adjustment comes from a sleeve over, or Proper coil over strut , the main advantage of a proper coil over is the height adjustable range . Its more on a coil over than sleeve over. From a performance point of view it doesn't matter which way the height is adjusted . hope that helpsThanks for the sarcasm
A quick link would be great
Only asked
Andy
At 40 mm there is no need unless you already sense there is a problem 40 mm will not change the wheel alignment at all .
If you want to check it there is a company next door who we can pop in to and get it checked ?
We would always recommend an alignment after any suspension work, especially as most come out of the factory with the steering wheel misaligned to the right .
I’m surprised you don’t offer this service or even have the equipment to do it yourself. Correct alignment is a massive part of our business.
Project twin Tube ( Chilli jam KONI kit ) 40 to 70 mm H&R 50 to 80mm Because the H&R kit is a proper threaded body coil over it has more adjustment ./So what are the drops of chilli and the drops of the CRS kit
What’s the cost on these?Project twin Tube ( Chilli jam KONI kit ) 40 to 70 mm H&R 50 to 80mm Because the H&R kit is a proper threaded body coil over it has more adjustment ./
Had a very pleasant chat with Steve @CRS Performance this morning. As a consequence, I have now ordered ( 2016 T6 / T32 / 4Motion ) Koni Sports Shocks + 50mm Lowering Springs + H&R Hub Centric Spacers (20mm front and 25mm out back). My goal is handling / comfort, and aesthetics in that order. I'm running standard 17" Devonports at present. Should look far better when the arches are filled out. I shall contemplate the LV-1 Leighton alloys when the new colours are released.
Would just like to thank everyone for all their posts, photos and intell. on this front. This forum is a gold mine of information. Had I lived nearer CRS, Bognor, Leigthon etc I would have used them for fitting. I'm up in Aberdeen so now looking for a local garage that won't turn their nose up at fitting parts they haven't sourced. Have driven well sorted hot hatches all my life so looking forward to banishing the corner wallow on my van ( especially noticeable on an unladen T32 ..)
Thanks,
Cal
Hi Calsonic.. Would love to see the finished drop with the 50mm and the report on the koni sport active.. This is hopefully the route I will go for 40 or 50mm? Not sure if I can stretch to the alloys straight off so it would good to see the drop with the Devons...Had a very pleasant chat with Steve @CRS Performance this morning. As a consequence, I have now ordered ( 2016 T6 / T32 / 4Motion ) Koni Sports Shocks + 50mm Lowering Springs + H&R Hub Centric Spacers (20mm front and 25mm out back). My goal is handling / comfort, and aesthetics in that order. I'm running standard 17" Devonports at present. Should look far better when the arches are filled out. I shall contemplate the LV-1 Leighton alloys when the new colours are released.
Thanks,
Cal
Sounds like we're in the same boat here. I also have a T32 but the new 6.1 model. It only arrived on Friday and I'm keen to get the ride sorted ASAP. I guess being a T32 makes a difference too. I will probably only go 18's though as comfort is a big priority of mine.Had a very pleasant chat with Steve @CRS Performance this morning. As a consequence, I have now ordered ( 2016 T6 / T32 / 4Motion ) Koni Sports Shocks + 50mm Lowering Springs + H&R Hub Centric Spacers (20mm front and 25mm out back). My goal is handling / comfort, and aesthetics in that order. I'm running standard 17" Devonports at present. Should look far better when the arches are filled out. I shall contemplate the LV-1 Leighton alloys when the new colours are released.
Thanks,
Cal
Where in Aberdeen. I know a guy in Oldmeldrum who has gone out on his own but was a vag tech for many a year......his prices are very good. Just had my timing belt and pump done by him. Pm me if you want his details.......very knowledgeable and approachable guy.Had a very pleasant chat with Steve @CRS Performance this morning. As a consequence, I have now ordered ( 2016 T6 / T32 / 4Motion ) Koni Sports Shocks + 50mm Lowering Springs + H&R Hub Centric Spacers (20mm front and 25mm out back). My goal is handling / comfort, and aesthetics in that order. I'm running standard 17" Devonports at present. Should look far better when the arches are filled out. I shall contemplate the LV-1 Leighton alloys when the new colours are released.
Thanks,
Cal
