Afternoon All. I've finally got the point of having installed my wheel, with the correct buttons and wired up as per the whole pin 36 on BCM and stalk pin wired into T10 under the battery req.
Deaky was good enough to help me with the coding but we only managed to get the stereo and horn controls working. On Attempting to code the ECU (Byte 5 Bit 5) We got the dreaded "Out of Range" message. Also there was no option in the BCM for selecting CCS in the long code helper - Despite the BCM being the 937 090 version that can apparently 'do everything'.
So I'm at a bit of a loss now, any thoughts & advice on what to try to fix this would be greatly appreciated.
Right now on Carista I'm getting the following faults (following a Fault Reset):
Central Electrics
00671 - Cruise Control Switch (E45)
CAN network gateway:
01044 - Control Module Incorrectly Coded
Deaky took this readout of my coding on Friday:
Friday,28,February,2020,13:24:52:32461
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.2.2 (x64)
Data version: 20200210 DS308.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZGH086192 License Plate:
Mileage: 68850km-42781mi Repair Order:
Gateway Installation List: 7E0 909 901
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 19,7E0 909 901 ,recoded (Installation List),from,5D0A1C08108000,to,5D0A1C08100000,,
Address 01,04L 906 056 KM,recoded (Long Coding),from,0019401C431401090000,to,0019401C433401090000,(02737/790/50316),
Address 09,7E0 937 090 ,recoded (Long Coding),from,A0F4793A0A613413922049642C2B8CD40D006989604449E0320400BF0800,to,A0F4793A0A613413922049642C2B8CD40D006989604449E0320400BF0840,(50376/001/1048576),
Address 09,7E0 937 090 ,recoded (Long Coding),from,A0F4793A0A613413922049642C2B8CD40D006989604449E0320400BF0840,to,A0F4793A0A613413922849642C2B8CD50D846989604449E0320400BF0840,(50376/001/104857),
And these pics show the details for my ECU and BCM
