Hmmm.. got a link for those @andys might have a look at those..View attachment 33270
Just the caps to sit them in, makes it a bit neater
Here you goHmmm.. got a link for those @andys might have a look at those..
Hi @DeakyYes, if you connect the, to the blue/grey wire in the door cards they will dim with the dash lights.
Hello DeakyGot bored today so while I’m waiting for my genuine ‘velle doorcards I had a go myself. They look pretty good. They’ll be up for sale shortly
@DeakyHello Deaky
Firstly, it seems so weird calling you Deaky, this has been the nickname of my eldest daughter since she a little un (she is almost 30 now).
Is Deaky anything to do with your surname?
Everyone calls me Deaks as my surname is Deaker.
Anyway, I have a question for you about the led placement.......
I can see you have put a white led in the door lever part (white), is it facing forward and behind the lever hinge point?
Did you but one in the top handle part or not?
The middle section, is that two LEDs?
How many are in the bottom section?
I was thinking of flush mounting the LED in a 5mm hole and held with a dab of hot glue from the back instead of using a bezel, but not sure.
Sorry for so many questions
TIA
Deaks
Hi MateHello Deaky
TIA
Deaks
I'm known as Deak, Deaks or Deaky
Thanks for the info and tip on led placement. I remember having a 3rd party hands free thing in the car that almost burnt my retinas out every couple of seconds with worlds brightest blue led.Hi Mate
LOL I have to do a double take every time I see your name. My surname is Deakin so I'm known as Deak, Deaks or Deaky
Middle and lower pockets have 2 led's in each. There is a single red in the top handle - If I was doing this again I wouldn't bother with this one. The passenger side will catch your eye when driving.
The white one in the lever is by the hinge pointing towards the front of the van.
Best thing to do is put a sticker where you want to place the lights then sit in the drivers seat an look if you can see any of them. If you can't - happy days. You'll probably want to put a resistor in series to dim them down a bit too
Yes, I used these 2.8mm Connector Plug Socket Set 2/3/4 Way Pin Male&Female W/Wire Motorcycle Car | eBayHello.
Did you use a connector to connect the leds to the exciting wires, so that it can be unplugged if removing the door card?
Yeah. Exactly the sameCan I ask if this will also be compatible for my T5.1.
Hi Mate
