I’m planning on doing both, should be doing it now but decided to clear out the shed instead. I think I need to reprioritise!!Dear God..... It's a thing of beauty! I need to crack on with fitting my puddle light kit. Do you think I could run both? Honestly.... If I had the ability, mine would be lit up like a 4 wheeled brothel..... Love ambient lighting! Top class mate!
I just looked on ebay and those led kits are out of stock.... Ah well.... You snooze, you lose! Let us know how you get on. At least I can dream! Right.... Better go cut some more grass.... Such is my rock n roll lifestyle!I’m planning on doing both, should be doing it now but decided to clear out the shed instead. I think I need to reprioritise!!
That is superb! Are the red and white lights running off the ambient circuit? Also did you use any resistors to reduce the brightness?Here are my lights. Made up the loom etc myself. 6 LEDs in each door (2 white and 4 red). Also fitted mirror down lights. All work perfectly well.
Yes, running off the ambient circuit - come on with the lights and adjustable with the dimmer.That is superb! Are the red and white lights running off the ambient circuit? Also did you use any resistors to reduce the brightness?
0.5mm or thicker will be fineThink I’m going to give this a go this weekend. I’ve got all the resistors, connectors, clips and LEDs now. I just need to get some wire for it all. What size / rating wire are you guys using?
Looks like a very even light, whereabouts did you put the LEDs?
