Keef, What size LEDs you using and also did you use a resistor?View attachment 87907 Got my Caravelle cards from Ebay (Poland), they came with handle LEDs which I wired in. The pocket light had a lens but no light unit. So I wired in a set from Pocket Lights.com - see pic. Doing footwell lights next!
Ah ok was looking at making my own. Just wasn't sure on what size LED to use brightness wise. Do you know if they are 5mm or 10mm?![]()
VW T6 Transporter Door Card LED Pocket Lights Interior Ambient Light Kit LED | eBay
The Original, VW T6 Transporter Door Card LED Pocket Lights Interior Ambient Light Kit. Light up the interior door pockets for added style & ambiance. Featuring high quality IP65 waterproof Superseal connectors and ultra bright LEDs to illuminate the Door Card Pockets.www.ebay.co.uk
Well I finally got around to it and pretty happy with the results. With all the bits mentioned above I built the kit and the brightness matches that of the instruments pretty well.
Thanks all
View attachment 86872View attachment 86871
Here are my lights. Made up the loom etc myself. 6 LEDs in each door (2 white and 4 red). Also fitted mirror down lights. All work perfectly well.
It points at a short across your new lights. Are the wires sufficiently insulated at the led end? Nothing would blow a fuse otherwise. Might just need a continuity test on a multimeter to check that they are not short circuiting, then you could dig deeper if not .Not my night. Got the pocket lights connected and working. Seem to have blown a fuse for the interior lights and tail lights now. Changed the 7.5 fuse and it blew straight away. Any ideas guys? Pocket lights connected to blue/grey for positive and brown for negative. Everything was fine till I fitted pocket lights.
Hi @Keefff no joy I disconnected the leds this morning and still blowing fuses. I seen a guy this afternoon who’s gonna get a look hopefully this week. I haven’t touched anything else so will be interesting to see what’s causing it. Doesn’t help in the meantime though with it being dark so early.@Kennymac did you get your fuse issue sorted? I test any wiring/lights I fit off the vehicle first with multimeter or fused 12v supply. Just fitted the van style footwell lights; again a simple job posi-tapped into the courtesy light circuit behind the lower glove box as per info on this forum
