So was it just software or did they add a shim too?Well, the deed has been done.
That’s what he said in his post (#55)? I just wondered if he’d had them both mapped out?why map out EGR and AdBlue they are unrelated systems?
I'm with you now..That’s what he said in his post (#55)? I just wondered if he’d had them both mapped out?
So did they map out the EGR and the ADBLUE??
I hope it all works out for you.![]()
Is the DPF regeneration still taking place?
If you want opinions on a remap it depends on the engine code (type), four letters.Hi, my 2018 camper conversion self-build had the egr light come on at just 1 year old. It was flushed then but now out of warranty it comes on every 2 or 3 days. I use a tester to check the fault and wipe it. I have used several fuel additives, 3 x egr intake spray, use super diesel every other fill up, and now decided to go for an egr delete. The gent can remap it at the same time for more power or more economy.
Is a delete the answer to my issues or will it cause more issues in the future?
Will a remap affect the reliability?
What would you go for, power or economy or leave well alone?
That's your invitation to COP26 in the bin!Guys, I have the EGR blind removed from the Ecu, and the unfortunate update undone. The car works evenly, the DPf does not clog.
After changing the oil, the oil remains clean for a long time. And the car has good power, better than after the update.
Come to the table!Guys, I have the EGR blind removed from the Ecu, and the unfortunate update undone. The car works evenly, the DPf does not clog.
I'm not sure that translates into Polish.Come to the table!
It’s what Extinction Rebellion (or whatever they’re called) had as their strap line when clogging up London today!I'm not sure that translates into Polish.
Mind you, I'm not sure it translates into English![]()
Any update on your EGR delete @Ali-G …. how’s your van running?No, they were going to but when I arrived to collect the van they said that they couldn’t delete the Adblue on that engine, if they did it wouldn’t run.
Thanks, I’ll update if there are any problems.
Mapping out the Adblue was unrelated to the EGR problem, it was just that the garage said it was an unreliable system and they could delete it therefore removing the possibility of expensive repairs in the years to come.
I thought why not, might as well while it’s there.
They assured me that there would be no problems come MOT time.
Yes, one started this afternoon funnily enough.
Not sure to be honest, I was going to ask when I collected the van but clean forgot about it.
Thanks…. good to know.All good at the moment, no problems, I haven’t noticed any difference.
Engine warms up at the same speed, fuel consumption unchanged and still regenerating the same as before.
No mechanic could possibly believe that there is any link between a defective EGR unit and a timing belt / water pump renewal.Ok my histological is that last year 2020 timing belt / water pump was done ... The VW clinic said that this was the issue and would clear fault with egr. I went ahead with this for two reasons. 75k on clock bought second from van monster (I don't recommend). Any how as I said the "service engineer" said it would sort out the egr issue also. I was learning at this stage so I had trust in VW. He said possibly van was driven hard.
So the whilst there bushing and spring was changed in rear axle. I got both done as I feel as a pair is better then one. And cost was minimal to do two as one. Never saw a spring break previously but it happens! Makes a real rattlesnake noise when you're driving. Must have broken that week. Couldn't hear anything due me been deaf, I read lips etcetera.
timing belt and pump changes full service done, the egr code stayed clear for three months then on some city driving after lots of motorways it comes on ...
Back in to vw.. its fine and we shall delete the error code. same again three weeks later, same same. Then again so I brought it to another VW garage they recommend a new belt and water pump! then they look at the computer and penny drops on technican's face. Yeah change of approach. It needs xyz.
Ok, In between I've learned and read and studied the forums all of them. What the hell the egr is where what where...Went to garages asked questions takes to people.
Then I spoke to one guy in his own back shed small name garage and we talked for a ten minutes. He spoke I spoke and we agreed. Obviously I was checking his knowledge out. Change the complete valve. I agreed
So he told me straight out what he thought was the problem. valve is stuck partly closed with crud. Yea I just got my egr complete replacement. Cost me 800+ euro. Got code cleared. And drove the sh1t out of it over 400 miles one day and then three days of continuous city driving. I'm impressed to say the least . Power is up, less fuel been burned. Crazy stuff overall. VW garages have a lot to say for them selfs. I'm happy with the van but never will I service it in VW again.
There's "skilled and qualified' verses experienced, interested, skilled and qualified. I'll be taking apart the old egr and will put photos online soon. that little garage has my future business
Hope this helps others.
