@Soundz
The 12/12/30 is advertised as 30A, at 40degC temp continuous.
It's actually capable of 40A for sort durations and has an absolute max of 60A.
That's why you need a 60A fuse.
And in any case fitting a 30A fuse on a 30A circuit is a recipie for disaster....the fuse will get hot and melt the holder.... At 30A fuse might not actually blow untill 40 or 50A. (Depending on the ambient temp, thermal mass of the fuse and holder, voltage , current which will all add up to either a quick blow or slow blow of the fuse...... Or just get hot and melt)
A fuse it fitted to protect the cable, not the device.
The fuse must be the correct size for the cable.
The cable must be the correct size for the load.... The 12/12/30 in this case.
So I would follow the manufacturer guidelines and fit a cable run suitable of carrying the max 60A+overrate @25% and fuse at the recommended 60A.
thats a 16mm2 cable and a 60A MIDI style fuse. ( well two fuses, one at the starter battery, and one at the leisure battery - see below)
Knowing that the 12/12/30 will pull 30-40A max.... Which will keep your cable run and 60A fuse cool..
There is also the volt drop to consider... Fatter cable, fatter fuse means less volt drop leaving more power for your charger to play with.
Fwiw ...
I have a 12/12/30 .... It's very good as is all the Victron stuff ...
BUT.
It's very big in size.!
It get very hot when running! (At 30A)
Compared to the 50A Renogy which I'm running now that stays cool as a cucumber..
I don't know why the unit is so big or why it gets so hot for a 30A box.
But take those into consideration and it's a good unit.
So be cautious of what your being told.... And defo don't fit a 30A fuse. !!!
Always follow the manufacturer guidance.
www.victronenergy.com
Fwiw ...
BUT.
Orion-Tr Smart DC-DC Charger Isolated - Victron Energy
The Orion-Tr Smart DC-DC charger is a professional DC to DC adaptive 3-stage charger with built-in Bluetooth. For use in dual battery systems in vehicles...
