It is this wire…@t6blo Thinking about this some more.
Do you know the specification of the cable you’ve used? Known manufacturer? Known supplier?
Definitely copper core?
@t6bloThanks @EAN
I am using these ferrules and inserting into the fuse holder and clamping down with the supplied gold plated grub screws.
The cable was from Amazon UK and came in a Vibe kit blister pack which included some RCAs and speaker cable. It is an 80a ANL fuse.
Good/cheap/Aliexpress don’t usually appear in the same sentence. It reminds of the young lad that goes into a second hand car dealership & asks for a fast, reliable, cheap car. The salesman tells him to pick 2 out of 3.….is there something good and cheap on aliexpress..
@t6blo
I expect that the connection between the grub screw and the ferrule is forming a resistance that is, potentially, the cause of your heating issue. Cant guarantee it but cable seems sound so that’s where I would think the problem lies.
i would personally replace them with midi fuse holders that have a decent bolt down connection.
High Power Fuse Holders
Suppliers of high quality electrical parts, components & accessories for campervans, motorhomes, boats & off-grid applications.www.12voltplanet.co.uk
My only thought here is that Vibe normally supply cables for the audio market rather than power distribution.
While amplifiers can generate huge surge currents the equivalent continuous current can be remarkably low, so the physical cable makeup may be optimised for that. In particular audio type cables tend to have a much higher number of finer cores.
For high current use you really want to use the battery type crimp terminals that need a lot of force - the idea is that the force is sufficient that it melds the soft copper into a single mass so current can easily transfer into all the cores (as well as keep corrosion out)
Battery cable crimping tool recommendation please
next up is this beauty . . . my first port of call and go to large crimper. it will crimp most large lugs and crimps . . . . if it fits on the gap . . . it will crimp it. I've have some tough crimps before . . . and even with 15stone leaning down on it its not broke. its big at 13 inches...www.t6forum.com
Yup, any local auto electrician will make the cables up for youIn the past I’ve gone to a local motorfactors with measurements and they’ve made me cables up quite cheaply.
John.l
@t6blo If you were local to me I’d certainly help you out, but you are about a 6.5hr round trip from me.
Hopefully someone nearer to you on the forum will assist.
John.
Just to add to this they now do a BB1210, which is a software downrated version of the BB1225.I only need it to run the fridge on days out and lights for a few hours - we're a day trip van not a camper.
50ah should give us broadly the capacity of a regular AGM but be a lot easier to tuck under the seat bases.
I actually want to try and downrate the charger (which you can with the remote) as I want to repurpose the existing 30amp towbar feed to avoid disturbing much while I'm still in factory warranty.
what's with the 3rd one?Good/cheap/Aliexpress don’t usually appear in the same sentence. It reminds of the young lad that goes into a second hand car dealership & asks for a fast, reliable, cheap car. The salesman tells him to pick 2 out of 3.
I'm not sure I understand what you are doing here but to run equipment off the second battery you will need to move it's supply to the second battery.How do I wire it up so the factory webasto takes its electricity from the 2nd battery? If I take out the relay and put +12v "engine on" to DC DC charger, and connect the thick wires through the DC to DC charger then to battery, where/how is the current flowing into factory webasto? I'm not sure, but I think I hear the relay clicking when webasto is started, with engine off. That would mean, the 2 batteries are connected in parralel and in fact power is drawn from both (by the webasto, in parked mode)?
