That doesn’t look like the same bulb that I used. It looks longer because the shiny black bit between the connector and bulb head is much larger. The bulb is also black rather than silver (not that will stop it fitting!).Holy smokes, how did anyone get these bulbs to fit View attachment 218008
I have sent mine back.. too long.. got to a point for trying "force" them in, which could create a problem when they need replacingThat doesn’t look like the same bulb that I used. It looks longer because the shiny black bit between the connector and bulb head is much larger. The bulb is also black rather than silver (not that will stop it fitting!).
Maybe they have changed the design? Link to mine below. And pic to show it looks shorter.
20Twenty LED DRL Bulbs
Carista can be used to alter the behaviour of the DRLs. As factory, mine were on regardless of handbrake position, but I can make them deactivate with the handbrake on if required.As soon as I put my handbrake down they lights came on. My van is a 2019 high line, yes, my drive is on an incline with the front end down.. perhaps easier to say a decline??
When I looked at theirs a year or so ago none of them were Canbus compatible. Without that they will trigger a fault. The Twenty20 ones from Autobulbsdirect don’t trigger the warning.Has anyone tried Osram LED bulbs from ECP as DRL in H7 headlights and its fault free?
Finally getting round to fitting my H7 this weekend.
Regarding these, I recently had to return mine to them as they would not fit. They said that the design may have changedWhen I looked at theirs a year or so ago none of them were Canbus compatible. Without that they will trigger a fault. The Twenty20 ones from Autobulbsdirect don’t trigger the warning.
DRL bulbs
IMHO, Yes is the answer to your question (with the same standard halogen bulbs in both). But as @Stay Frosty and @dubber36 are politely discussing this is a pretty subjective assessment so as they say "your mileage may vary'.I went for the H7's because I just wanted a better dipped beam. I know H4 have same 55w but my H4 with 200% Osram bulbs are still terrible, will the H7 beam be much better?
Yes.I went for the H7's because I just wanted a better dipped beam. I know H4 have same 55w but my H4 with 200% Osram bulbs are still terrible, will the H7 beam be much better?
If you can find a set cheap on eBay or elsewhere its a cost effective upgrade to the standard H4's.
If you have them, then fit them!I have a set sat in a box in the garage, just contemplating whether or not to fit them, having to go and spend another £50 on two twin pack Osram 200% bulbs.
Thanks for the helpful response.
Yes they are, but not the Valeo OEM ones so the finish and/or performance may not be as good. You may also need to swap over the height adjustment motors if they are not included.
And definitely do the bulbs, easier when on the bench than later.
Although, you really only need the dipped, that's where the big difference is, the high beam isn't such an issue.
