Andrew Wilkinson
Thanks. Are they an easy fix? Easily accessible? Or job for an auto electrician?Fan resistors are a common failure. If so, the fan won't blow anything on the lower settings, on full speed.
Thanks Littleblackflash that's really helpful. I guess I know what I'm doing this weekend.I think everything is an easy fix but I design cars. This thread might help
Heater Blower Speed
Hi Chaps Just noticed tonight my heater blower is only working on speed 4. I’ve got the manual Air Con, rather than climate. All other functionality works ok, just nothing blowing out until you select the fan blower at speed setting 4. Anything obvious to check? Any known issues? Thankswww.t6forum.com
I doubt it’s to do with making money in this case as the poor reliability will affect reputation rather than boost the coffers.I also thought about the same thing but in my opinion it is safer approach to have single trip device rather than multiple.
On the other hand this resistor pack itself is a very robust component but I am convinced that VW purposely uses low quality thermal fuses (even though rated for correct temperature of 192°C). And this obviously works for VW cause they keep on making money on spare parts.
550 quid??? That must be a typo, it’s a 15 min job.Just saw this post. This happened on my van. Took it into a VW garage for them to have a look. I had already googled the problem, which told me it was probably the resistor. I don't really like messing about with motors so hence the visit to the garage. They managed to get the quote up to circa £550. I did it myself for the cost of the resistor.
