In the large wardrobe the rear. Discussed a few options and that worked for us. I know I now cant ram the wardrobe chock full off clothes and bedding, potentially smothering and overheating the MPPT, which might be a concern for others who don't pack light.@Phil TL where did they put the Victron MPPT in your install?
It’s really easy to access the water-pump locker. Open the rearmost locker under the countertop, then lift out the drop-in bottom panel. It’s a little bit awkward to work in there but certainly not impossible to install the Victron MPPT controller in there (as @EAN has shown with his EHU charger install). I figure that there’s enough airspace in there to keep the charge controller within its specified operating temperature range.I havent got into the void where the wheel arch is yet. EANs post looks like he got down to it from the cupboard above, I will look at it tomorrow.
Yes, easy enough; I removed the hinged door from the external cupboard so it didn’t accidentally get damaged whilst I worked in there. I’m going to put my 2nd MPPT in there too (30A Victron - all planned out), but using the van has taken priority, so likely not to be done until this camping season is over now.It’s really easy to access the water-pump locker. Open the rearmost locker under the countertop, then lift out the drop-in bottom panel. It’s a little bit awkward to work in there but certainly not impossible to install the Victron MPPT controller in there (as @EAN has shown with his EHU charger install). I figure that there’s enough airspace in there to keep the charge controller within its specified operating temperature range.
Thanks guys, will take a look and measure up to see what I can do about upgrading my charger in there.Yes, easy enough; I removed the hinged door from the external cupboard so it didn’t accidentally get damaged whilst I worked in there. I’m going to put my 2nd MPPT in there too (30A Victron - all planned out), but using the van has taken priority, so likely not to be done until this camping season is over now.
@Phil TL From working on my van, the main feed from front to rear was no bigger than 6mm2. If it was larger the crimp connectors wouldn’t have fitted. I’m definitely going to rewire front to back with larger and additional cabling, when time allows.
Just went to have a look in that area to checker charger and plan what I am going to do... But mine doesn't have the drop in panel like yours. See photo. I've unscrewed the right angle brackets thinking the whole shelf would then lift up but it won't budge.It’s really easy to access the water-pump locker. Open the rearmost locker under the countertop, then lift out the drop-in bottom panel. It’s a little bit awkward to work in there but certainly not impossible to install the Victron MPPT controller in there (as @EAN has shown with his EHU charger install). I figure that there’s enough airspace in there to keep the charge controller within its specified operating temperature range.
Is your model a Birchover? It looks like HL have re-sited the water heater in your conversion. I’m just wondering what you’ve got in the space underneath the rear wardrobe.Got into it. Sorry ;for the commentary... Maybe the pics will help others with this version.
Yes, Birchover Executive, July 2023 it was registered.Is your model a Birchover? It looks like HL have re-sited the water heater in your conversion. I’m just wondering what you’ve got in the space underneath the rear wardrobe.
I noticed at the NEC that Hillside’s Ford-based Castleton (essentially the same as the new VW) has the water heater located in the traditional location below the wardrobe…
It’s interesting to note the differences between the various Hillside Birchover offerings. As well as the 5 main Birchover models I’m aware of a few special customised T6.1 variants that combine some of the features and specifications of the main models. And then there are the conversions that Hillside have produced for third party campervan vendors who market them under their own branding.Yes, Birchover Executive, July 2023 it was registered.
Under the wardrobe is just the gas bottle locker, nothing in between. Nice deep wardrobe.
