How to fit a DC-DC / battery-to-battery charger kit
Thank you very much, But I think that I have this connector:
Can I use just one live wire from this connector and connect it into Victron's Remote-H ?
Use that wire to control a small relay, use the relay n/o contacts to go across your remote control terminals.
Step 6, mount the DC DC charger and parts.
Mark holes for the charger, drill and mount the charger on the side of the seat base towards the rear.
Connect the 2 leisure battery supply cables to the large power post with the Output wire from the Charger, feed all 3 cables up the sleeve of the protection cap, but leave the nut loose for the time being. This is the large brown cable on the Redarc unit.
Connect the main battery supply feed to the midi fuse carrier at the end of the supply cable to the charger. This is the red cable on the Redarc unit.
Now mark, drill and mount the power post and midi fuse carrier so that it looks like this , ensuring the main supply cable is well away from the seat base.
View attachment 19102View attachment 19103
Now tighten up the nut on the power post and slide over the rubber cap. tighten up the nuts on the midi fuse carrier. I also added some insulation tape to the battery supply cable as there was too much bare cable for my liking.
Next I fitted a bolt to the seat base to act as the earth for the charger and connected the earth cable from the charger. As the california has a battery monitor the negative must go directly to the chassis and the reason I improved the earth to the seat base earlier. (If you do not have a battery monitor this cable can be put under the nut of the negative battery clamp)
Next connect the trigger wire for the charger to the relay plug we removed from the relay earlier.
Tidy up and cable tie your installation.
Continue to Step 7.
Dear Loz, thx a lot for very good explanation. I have question about conecting trigger wire for the charger to the relay plug. There is no plug in charger side, when you buy it (as I see in manufacturing site).... Whats happened, if you do not conect relay plug to charger. Sorry, I do not know much about car electricity...
OK, we have taken this on board and can now supply the truly plug and play option for the variants using the single battery factory upgrade with relay 100. This also incorporates the ignition supply and a negative for those chargers that require it for battery type selection. Fully potted.
Does anyone know an alternative source for this plug and play adapter, or have one spare they would be willing to part with?
I bought a CTEK and plug and play cable from Travelvolts 5+ years ago. When the CTEK stopped working around 2+ years ago, I bought a Victron Smart charger. The smart charger somehow senses the change in voltage when the alternator is running and does not require a trigger cable. My advice would be to get a smart charger.
I was going to consider a Victron. This is good to know for sure. Thanks.
Hi @travelbolts,
I know your shop is closed, but I would like to mount a Victron dc dc booster on my 2018 Cali Beach with relay 100 and I think this plug and play cable is a good solution for me.
Do you know if I can buy it, or something similar, somewhere.
I write you from Spain.
Thanks in advance.
