Did a possible fix on my leaky sliding windows.
Ordered some 3mm, 4mm, and 5mm foam rubber cord and fed this into my 2x sliding window seals (one had already split at the join, the other I made 2x small nicks to feed it it) with the help of a spare bicycle gear cable fed through to pull the cord back through.
On first test, after removing the copious amount of silicone grease which was keeping the seal watertight (but is only a temporary fix) it seems to have worked. My thinking is that the seals are hollow and they're not making a tight enough of a seal against the outer glass. The 4mm stuff fits perfectly, I tried the 5mm but there's just too much friction when pulling it through, even with lots and lots of lubricant (fnarr).
The windows aren't any harder to close, chucking some water directly at the seals and they seem to be sealing and not letting any water through.
We're due some heavy rain tomorrow overnight and in the past there's been a swimming pool in my side step so I'll see how it fairs.
Borrowed your idea and have just fitted 4mm foam cord into my seals and on first test it seems to have done the trick.
I need too wait for it to be dry and warmer until I seal up my detached drain though.
