It wasn't empty! - Which is a surprise......Great use of an empty beer there,
Ok, no problem....Thanks @Dellmassive I read your review about those, and it sounds perfect, my only problem is that my solar panel is more than the recommended 'Max. Solar Input Voltage : 25V' - I'm not sure what the impact of having a bigger voltage panel would be
Infact I can't actually find many solar panels with less than 25v!
Thanks for the response! The panel is 315w, vmpp: 33.7V impp: 9.36A voc: 40.6V - So that leaves me at a 30amp MPPT I think!
My concern was how to stop any charging (solar or alternator) when the temperature is low that it'd break my batteries!
I guess I have a couple of options;
1)
Sell EPEVER MPPT and buy a Victron 100/30 MPPT
Buy BMV-712 with temperature probe - this can tell the Victron MPPT to stop charging, right?
Buy Renogy unit and leverage their LTD for alternator charging!
2)
Buy BMV-712 with temperate probe - how would I setup this to stop the EPEVER from charing?
Buy Renogy unit and leverage their LTD for Alternator chargng!
1)
Sell EPEVER MPPT and buy a Victron 100/30 MPPT - Thats a great unit =] ( Victron Energy SmartSolar MPPT Solar Charge Controller: Amazon.co.uk: Electronics )
Buy BMV-712 with temperature probe - this can tell the Victron MPPT to stop charging, right? ( correct - see setup here > Lithium Lifepo4 12v Batteries - - - Time For An Upgrade ? - - -)
Buy Renogy unit and leverage their LTD for alternator charging! - yes possible option
2)
Buy BMV-712 with temperate probe - how would I setup this to stop the EPEVER from charing? - set BMV712 alarm output to low temp alarm, use this to toggle a relay that will disconect the solar panel from the MPPT. (unless the epever has a separate disable input (I've not looked at the specs))
Buy Renogy unit and leverage their LTD for Alternator chargng! - yes possible.
another option is to keep/sell the solar panel and swapp out for 2x lower wattage units that could be run in parallel. . . . to keep the VOC lower.
though the higher VOC is favorable so you can keep the wire sizes smaller . . . . I've got 3x150w running in series on my shed . . . . which is a more efficient way of running them . . .
Solar Sheds & Other Non-t6 Solar Projects - How We Done It -
Solar Sheds & Other Non-T6 Solar Projects - How We Done It - @Pete C requested it, so here it is . . . . . Dell, What do the batteries in your shed power ? I too have a solar powered shed - perhaps we should have a separate thread for sheds :) Pete Lets Post here any NON - T6 related ECO...www.t6forum.com
SOLAR:
Solar Pwm & Mppt Controllers - How I Done It -
Mobile Solar Panels ? . . . - How I Did It -
What Solar Panel & Controller ?
Solar Panel Cutting Hole In Roof !!!
300w Solar Club -- How I Done It --
great news . . . . =]Thank you @Dellmassive - noted and updated!
I have just placed an order with @travelvolts - very excited to get working on it!!
Renogy has added a bluetooth dongle but I think it's only for a few of the larger MPPT chargers, they don't do anything for the dc-dc side..... the 50A dc-dc/mppt I'm currently running does have a rs485 bus on it but I've not seen any software that works with it...
I have an arduino solution working for this. I got the modbus data map from renogy and I can show all the data on a small OLED display. I plan to fit it in the blank panel behind the overhead cab light switches. The hardware cost is peanuts, although the larger (more readable) display I ordered from China could take any amount of time to arrive, so I can't finish the job yet. If anyone wants the code, just ask.
