Dont know how i missed this news . . . . . . . . but,
LifOS release a 105ah Lithium . . . . finally !! (
@ROMANY TAMPIN - possible upgrade?)
still no LTD, but hey its 105Ah . . . now inline with most of the other guys.
and they have changed the sales pitch to clearly state the Ah capacity as it is . . . and then mention the equivalent SLA capacity - well done guys. =]
cap -105ah
life - 5000 cycles @ 50%dod
dim - 328 x 177 x 233mm
max discharge - 100/120/150A (-20-60degC)
charge - 20-50A @ (14.4 - 14.6v) (0-50degC)
LTD - NO (dont charge below 0degC)
LBD - NO (recommended, add ur own @ 11.2v)
Lifos Advanced Lithium Power
Lifos 105Ah/12v Smart Lithium (LiFePO4) Battery (LB0105)
As the flagship in the Lifos range, the Lifos 105 is the only choice where maximum power, minimal weight and longest cycle life are critical. Whether used to power electric marine motors or in large RVs, off grid properties, for on location audio visual equipment power, powering emergency “blue light” equipment or in commercial applications such as road signage, the Lifos 105 provides quick charging reliable power in all circumstances.
The Lifos 105 provides an amazing 2750 charge / discharge cycles with a 95% depth of discharge giving a usable battery capacity of 99.75Ah. To replace this a 200Ah lead acid battery would be needed but instead of weighing in at nearly 60kgs, the Lifos 105 is a featherweight 11.9kgs.
Lifos 105 can be connected with four batteries in series or parallel if a power bank is needed and each battery's internal BMS ensures all the lithium cells are perfectly balanced to give outstanding and reliable performance.
Fitted with a Bluetooth
app, you can keep abreast of the vital information at all times when connected to an Android or Apple smart device. Information such as current, voltage, power (w) and state of charge can be interrogated at any time and the smart operating system even send you a warning well before the battery gets to a low state of discharge giving plenty of time to get it recharged.
Lifos 105 comes with a five year warranty.
datasheet -
https://irp-cdn.multiscreensite.com/231bdcf7/files/uploaded/LiFOS 105 Data Sheet.PDF
