I don't know how I happened upon this thread, but I'm glad I did
Never thought I'd hear the word 'QNX' again either, I remember playing with it 20 years ago back when I had plenty of time for weird and wonderful operating systems...
Anyway, I tried the steps previously with adaptations to get Offroad menu, which works until you come out and can't get back in again without doing the Hybrid trick. I have a 5C0035680B, HW 22, SW 0252, retrofitted into a T5.1, bought with CP off and all features enabled (allegedly) from an eBay seller in Poland. Turns out not the case - lots of FEC available but not active, but from reading some of the links, that's maybe not such a big deal now.
I am keen to update my software to get the new skin and extra features, I think I have the relevant tools, files and info required. What I don't want to do is end up worse off than I started, I have no idea what the people have done to this unit to enable features/remove CP. I do get some DTCs from the unit, which seem to correlate with someone playing with the software, and from reading, it seems there's simple ways to remove 2 of them (1555/1556).
Code:
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 B HW: 5C0 035 680 B
Component: MU-S-N-ER H22 0252
Serial number: --------------
Coding: 06570001FF00000001110001010808001F01008600200100CF
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 204F55873BC3EA8422-8074
Data carrier:
Subsystem 1 - Part No SW: 5NA 919 866 BG HW: -----------
Component: ECE AS 2021 --- 1520
Serial number: --------------------
4 Faults Found:
1555 - Check Software Version Management
B201A 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 32
Mileage: 206876 km
Date: 2021.05.31
Time: 17:45:18
Voltage terminal 30: 11.6 V
Status_Software_Version_Management-module_name:
1556 - Internal Control Module Memory Check Sum Error
B2000 87 [009] - Missing message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 32
Voltage terminal 30: 11.9 V
System_Software_Error-SW_Status_Consistency: 04 01 01
System_Software_Error-SW_Status_Device: o
15360256 - Component Protection
U1101 00 [009] - Active
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 32
Mileage: 206876 km
Date: 2021.06.02
Time: 14:41:46
Voltage terminal 30: 11.7 V
2565 - GPS Antenna
B1054 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 32
Mileage: 206876 km
Date: 2021.05.31
Time: 17:45:19
The update history on the unit also appears to indicate something has been messed with/changed (see attached).
I entered the GEM but there's no Mib2std Toolbox.
So really I have no idea what the people have done to the unit before, and I highly suspect they won't want to tell me as they'll think I am trying to copy their business or something.
So first question, will doing a software update remove any previous
software corrections to CP/FEC/SWaP? I think it should be OK to repeat all the software corrections with the new update if it is required. I appreciate most people here won't have CP issues due to the unit coming with the vehicle from factory, but from memory of previous discussions here/other forums
@dnoermann and
@Adams are running T5.1s too.
Second question, will doing a software update with the above corrections interfere with anything if it turns out to be a
hardware correction for CP?
Last question, I'm not sure how the software CP correction works, but if it works in a similar way to the hardware one where it resets the timer on each switch-on, would this affect the units maximum running time if, say, the software CP correction disappeared for a while due to an error by me, but was then re-applied later with new update?
I appreciate some of this may not be allowed, so apologies in advance...PM if required. In the meantime I'll keep reading...
