So i have a couple question for you MTBers as im a bit of a novice having only started ridding properly recently (last month to be precise)
I have a bike with avid juicy 5 disk brakes on it thats been stood up a while and the rear brake stuck on (if you push the bike the rear wheel drags and doesnt spin) now i thought the caliper had seized but on looking closer they hadnt so i gave the brake lever a few hard squeezes and it seems to have released and the wheel now spins ok and stops you ok when moving, is this a common thing following periods of inactivity ?
Should i do anything about it or just ride it and hope for the best ? Service kits are available for the lever or i could just replace it with a second hand one but dont want to make work for myself
The second question is regards a rear shock, i have a specialised own brand rear shock on a DH bike that does NOT have lockout
It has a compression lever (same style as Fox Float propedal level) that has four positions and seems to function ok and also has a red rebound adjuster dial behind it (again very similar to a Fox Float shock style) that has about 8-9 clicks on it, now if i dial the rebound too far in (last 2 settings) the shock will compress and stay compressed (fully bottomed out) until i dial the lever back out then the shock will immediately extend ?
Is this right or is it knackered ?
I have rang my LBS (specialised specialist) and they said outright over the phone its knackered and will need to be replaced but bring it in and we will have a look to confirm, i also rang a local MTB suspension service/setup shop who also said bring it in to have a look but its fine just dont dial it in too the last settings ?
Anyone heard of this before ?
Not sure if its relevant but it has long travel front forks that have a travel reducer on them when engaged it will limit the shock to bottom 2/3 of travel (100mm ish) then when you twist the dial back out the front extends back to full length (160mm ish travel)
I did wonder if the shock staying squat was a form of lockout but think using it like this will likely destroy the shock ?
Sorry for all the question marks i just dont know much about this sort of stuff
