Saturday,12,February,2022,13:30:44:28183
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZGH008151 License Plate: 06CTYRROOFERROR
Mileage: 194040km-120570mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 18 19 25 5F 61 6E 78 0B
VIN: WV2ZZZ7HZGH008151 Mileage: 194040km-120570miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
6E-Ctrl Head Roof -- Status: Malfunction 0010
78-Slide Door, Right -- Status: OK 0000
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 019 HL HW: 03L 907 309 L
Component: R4 2,0L EDC X38 8372
Revision: 22X38--- Serial number: 00000000000000 CVN: DB61D1D4
Coding: 0125401A232401080000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20BTD01103L906019HL 003005
ROD: EV_ECM20BTD01103L906019HL.rod
VCID: 7CCFC2D9F78570691D-8028
VINID: 9E60AAAAA1D8A9760000804504BAC51568
No fault code found.
Readiness: 0 0 0 0 X
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 045 T HW: 0BH 927 711 G
Component: DSG DQ500-7F H11 2402
Revision: 00H11V01 CVN: C3693820
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_001_VW37.rod
VCID: 46BB6031F9C9FAB93B-8012
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 41485000000456
Coding: 347E4098656284862C76027BA68321D3380000
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FB575D5A613AB7178-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 02061504651640
Coding: 01
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7ECBC8D1E199627933-802A
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E0 907 040 C HW: 7E0 907 040 C
Component: ClimatronicT5 H02 0508
Revision: 00001K03
Coding: 0004000502
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 237DD9A52ABBEF917C-8076
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 C HW: 7E5 907 049 C
Component: Heckbedienung H11 0303
Serial number: BHB-0010806150015032
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0733
Revision: B9080001 Serial number: 0771 146151065
Coding: 62F279BA0A21209201280F746EEB8FD48FA0690F60CC6960320402A30800
Shop #: WSC 02739 790 12345
VCID: 68E78E899B1DCCC9E9-803C
Subsystem 1 - Part No SW: 7E0 959 801 J HW: 7E0 959 801 J Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8654
Serial number: KU0KU001061551520700
Coding: 0400A3
Subsystem 2 - Part No SW: 7E0 959 802 J HW: 7E0 959 802 J Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8654
Serial number: KU0KU029051551494699
Coding: 1400A3
Subsystem 3 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J
Component: E221__MFL-DC1 H17 0103
Serial number: 39180000926670048207
Coding: A9FFFF
1 Fault Found:
01520 - Rain and Light Recognition Sensor (G397)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 38
Mileage: 194049 km
Time Indication: 0
Date: 2016.07.05
Time: 13:26:42
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 N HW: 7N0 919 475
Component: PARKHILFE 8K H06 0205
Revision: -------- Serial number: 28291509800873
Coding: 30810C
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis8K 001007
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 3D490FDDAC1FB9616A-8068
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 D HW: 7E0 959 655 D
Component: VW10Airbag00G 008 0016
Revision: -------- Serial number: 003PH000791J
Coding: 000000000000000000000000000000003047
Shop #: WSC 02754 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 37451DF58E239331B0-8062
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 870 L HW: 7E0 920 870 L
Component: KOMBI H05 1007
Coding: 170D030100
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 32532CE16541761987-8066
1 Fault Found:
15360512 - Component Protection
U1101 00 [009] - Active
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 38
Mileage: 194049 km
Date: 2022.02.12
Time: 13:26:36
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 272 B HW: 7E0 963 273
Component: STH-T5GP2 002 0009
Coding: 5101
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 2B6D3185426B27D1C4-807E
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000118204
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0733
Revision: B9080001
Coding: 042205
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 1007
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6AE3F4818D11FED9FF-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5K7 035 200 F HW: 5K7 035 200 D
Component: MU-S--ER H22 0368
Serial number: VWZAZ2R8886664
Coding: 06570000FF00000011110001000908001F0100D40020010002
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 2765CDB55E8303B120-8072
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0733
Coding: 030B1A73
Shop #: WSC 02737 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 G HW: 7E0 915 181 G
Component: J367-BDM H08 0223
Serial number: 52128359141261970656
Address 6E: Ctrl Head Roof (J702) Labels:. 7E5-919-037-W2.clb
Part No SW: 7E5 919 037 G HW: 7E5 919 037 G
Component: Dachdisplay H15 0175
Revision: 10100010 Serial number: 183836
Coding: 000203
Shop #: WSC 12345 123 12345
VCID: 355917FD9C2F6121A2-8060
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 8
Fault Frequency: 1
Reset counter: 38
Mileage: 194049 km
Time Indication: 0
Date: 2022.02.12
Time: 13:26:35
Address 78: Slide Door, Right Labels: Redir Fail!
Part No: 7E0 959 243 D
Component: Schiebetuer-SG 407 0328
VCID: 305726E9A34D4409F1-8064
End-------------------------(Elapsed Time: 02:59)--------------------------
