Thats exactly how i have done mine but thought that will do temporarily until i figure out how VW route the cable, i assumed it went down through floor and back up inside rear quarter
Think i will make my own hole to run it through
So how much for the rear door and side door kit?
They can be fitted singly or at the same time, the price is slightly cheaper if purchased together as all the wiring is amalgamated into one loom and the positive and negative power supply cables are pre joined to feed both modules simplifying it slightly for the installerRear single tailgate at the moment but I like the idea of adding it to the single side door at a later date. Unless you think it would be more prudent to do them both at the same time.
Are the part numbers you want not in the post above yours with the diagrams on?Have been slowly collecting parts for this build.
Parts shown on the photo:
Control module: 7E0959243E
Motorized closing plate: 7E0827511A
8-pin connector (goes into control module): 1J0972724
3-pin connector (goes into closing plate): 1J0972753
The used connectors were couple of Euros each and already have pins/wires connected - was really happy as I don't yet have the new pins or the skill to crimp them.
I also managed to get hold of a wiring diagram which seems very simple and is certainly not worth 99 Euro that Kufatec charge for it.
Will be posting all the detail as soon as I successfully connect and test.
For this I need to collect the remaining 2 pieces of the puzzle:
Does anyone know the part numbers for these please?
- Control module bracket
- Covering lock carrier
Also, I think I will need to buy 2 longer bolts cost for which is negligible: N90804705
No, because I am doing the tailgate, not the side doors. Even the bracket is different.Are the part numbers you want not in the post above yours with the diagrams on?
I was wondering why Kufatec would include a new one... thank you Pauly, German precision says that the part needs to be exchanged.The only difference on the rear strip is the foam packer underneath, it can be cut to fit
It's £12.99 for a full year membership: VIP MembershipMuch appreciated how much is it per month please also are all bcm compatible or only some thanks
