Sold REDUCED - Roamer Gen 1 200Ah Lithium Leisure Battery £275
Drive Wayne
T6 Legend
REDUCED!!!
Needs a wonderful new home!
200Ah Bluetooth Roamer 200S Lithium Battery, 3 years old, 68 cycles on the BMS App.
From a 2000 watt inverter, it powered a 2000 watt induction hob, a 1560 watt coffee machine, power drills/tools and more.
Too big to live under the passenger seat, it lived under the wardrobe in the rear of my van powering our off grid adventures.
49cm wide by 17cm deep by 24cm high.
I've swapped it for a new larger Roamer which will accommodate a 3000 watt inverter, you can never run too many power tools!
8mm terminal screws included, I'm all heart!
Happy to meet up somewhere for a nice buyer, no posting this, West Midlands/Worcestershire collection/delivery.
Hi im interested but need to know a bit more as cant find any info online, can this be just swapped straight from my acid leisure battery?
How many cycles can do? 7 years warranty it’s nice can this be transferred?
Sorry for all this but I’m green yet about batteries etc.
Mark
Oh and im from Stoke
Compatibility is nothing to do with the battery and all to do with your van and what kit you have fitted, as long as your kit has a lithium profile/setting then it should be ok but you would need to double check all that
If your not sure i would start a separate thread and post up all the details of the kit you have fitted and people will be able to advise
Mark
Hey Mark, there's many a thread on here about swapping from AGM to Lithium, you need a charger that's lithium compatible, the one I used was a Victron TR30 Bluetooth, plenty available on ebay second hand for less than £100. Fatter Cables, 25/35mm2 required, dependant on length needed, 300Ah fuse on the positive side.
More than happy to bring it to Stoke if you feel you can accommodate it, it is a big beast! Superb battery though, good for 4000+ cycles, I've done 68 in 2 years!
Have a look at the threads on the forum though, type lithium upgrade into the search bar!
Just got response from Roamer about warranty and unfortunately can not to be transferred ffs, but still customer service was quiet fast to respond and even find data sheet for this battery
Shame about the warranty but they are indeed so helpful. I've called them a couple of times and they have been great.
for an idea for this battery, for you, or the next owner.
a @Dellmassive Portable Power Station.
200ah you say? - so thats about 2400wh !!!
i made 5 in the end. . .
D
BTW. . . i also made a ROAMER 230Ah battery box. .
You'll be needing a bigger box! 50cm width.
I can see I'm going to end up donating this battery to the Forum for powering the Beer machine, Ice machine, and the new Cocktail making machine the girls have been talking about! Just need someone's spare 2000 watt inverter.
In the meantime, if someone wants a 3 year old big Bluetooth lithium in great condition only 68 cycles, it's available!
