Great cheers for that. I’m fitting them Saturday so I will temp rig them up for now but it would be good to get them running properly at some point.Yep that's the one I have ordered, can let you know how I get on with it.
let me know how you get on, be next week sometime for me.Great cheers for that. I’m fitting them Saturday so I will temp rig them up for now but it would be good to get them running properly at some point.
Hi AndrewFrom what I’ve read the electric seats don’t work on a swivel base? They wired them up with connector blocks but I’ve since re done them with oem plugs. Brown to brown, red to red are the obvious ones, I’ll have a look at mine later to see what the other ones are
perfect thanks for that, seats due to arrive Monday.This is the part you need for the drivers seat so you can move the memory model over.
Just collected mine and dropped off at Suffolk Campers who are fitting them. I will let you know how it goes.perfect thanks for that, seats due to arrive Monday.
I've just done the same - if you look on fleabay there is a kufatec wiring harness for T6 electric heated seats, not cheap but looks like it will sort any issues (fingers crossed) and make the install easy (I hope)
perfect, thanks again.
Hi. I’ve just done exactly the same as you. Mine has yellow plug too! Could you take a picture of your wiring now it’s done please, so I can see if I can do it?I've just bought a pair of genuine VW electric seats from a caravelle and stupidly assumed that they would pretty much be plug and play but of course it’s not that easy! My existing seats were already heated so those controls will already be there but I’m not sure about the power for the electric bits and any data cables there may be. Does anyone have any experience as to which cable does what and if the power should be a constant feed or on the ignition etc. Any help or advise would be greatly received! I’ve attached a photo of the plug from the new seat which appers to do everything, seat motors, seat belt and heater where as the old seat had two separate plugs, one for the heater and one for the seat belt
Andy
I haven’t a clue. I’m sure you’re right & im happy to ditch it too. But how do you get the black plug connected when all you have is this......not 100% sure but is that yellow plug not the one for the side airbags, the caravelle seats I recently installed in mine had this plug and I have just left it disconnected and everything electrical adjustment wise works fine.
