Seat-base dimensions - Leisure Battery Sizing
EAN
Just had a look at the Fogstar website.
They list a 230AH seat base battery similar to Roamer‘s offering but with slightly different dimensions:
[My quoted measurements are for actual install aligned to vehicle orientation]
Fogstar 275(w) x 315(l) x 187,5(h) vs Roamer 290(w) x 330(l) x 180(h): assuming electrical connections are orientated towards the front as per others installs.
Less money and slightly smaller, except in height.
Is there any reason why these seatbase batteries couldn‘t be fitted sideways to give more space at the front?
Currently I have a factory 2nd battery fitted that is 315(w) x 175(l) x 190(h) under a factory single swivel.
I then also saw that Fogstar list a 300AH battery that is effectively 345(w) x 240(l) x 190(h) if mounted on its side.
(Not that much bigger than a side mounted Roamer 160S at 338(w) x 215(l) x 185(h) ).
I measured the gap between the seat rails as 350mm and the seatbase opening is slightly wider.
Am I missing something obvious, as it looks to me that the 300AH might actually fit better than the seatbase battery offerings, taking account of all the factory connections etc at the front of the seat (passenger side) and also give more capacity?
Just checked with Fogstar before purchasing a 300AH and the obvious, that I was missing, is they don’t include the handles in their measurements.
The 300AH is therefore 380mm, rather than 345mm, making it a total non starter, unfortunately, under a single seat.
This is something I’ve been looking at lately, as my AGM has died.
Working off a seatbase size of 315mm length (without seatbase plastic its 385mm) width 290mm (tapers to 227mm at the top front section) and height of 190mm, here’s some Lithium Battery sizes I’ve noted -
Size AhLength in mmWidth in mmHeight in mmSeatbase fit?
Fogstar Drift 300Ah380mm Lx 190mm W x245mm H?
Roamer 230Ah Seatbase331mm Lx 285mm W x182mm HY
Fogstar Drift Seatbase 230Ah315mm Lx 275mm W x187mm HY
Fogstar Drift 230Ah380mm Lx 190mm W x245mm HY?
Victron 200Ah321mm Lx 152mm W x237mm HY
DC House 200Ah370mm Lx 190mm W x250mm HY
Renogy 170Ah357mm Lx 155mm W x270mm HY*
Roamer Smart4 160Ah330mm Lx 173mm W x229mm HY
Eco Worthy 150Ah300mm Lx 200mm W x275mm HN
Groves Titan 150Ah355mm Lx 175mm W x190mm HN
Eco Tree 150Ah339mm Lx 185mm W x218mm HY
Hypery 150Ah329mm Lx 173mm W x214mm HY
Super B Epsilon 150Ah353mm Lx 175mm W x190mm HY
Valence U27-12XP 144Ah360mm Lx 172mm W x225mm HY
Valence U24-12XP 118Ah260mm Lx 172mm W x225mm HY
Fogstar Drift 105Ah260mm Lx 168mm W x209mm HY
Roamer Xtreme 100Ah338mm Lx 185mm W x215mm HY
Renogy RBT100LFP12 100Ah265mm Lx 172mm W x222mm HY
Eco Worthy 100Ah260mm Lx 170mm W x210mm HY
TN Power 100Ah328mm Lx 172mm W x220mm HY
