This looks interesting Seatbase Jerba fans /
Just a question on this bit, it looks like you have installed a copper bus bar on both sides of the top connectors down to the distribution bus bars.View attachment 141331
High power distribution buss bar, that connects the two batteries, mppt chargers, B2B and inverter. I chose to fuse each battery to a buss, with equal 35mm cable each, and 75mm for the inverter. Next to the left is the bmv700,
Notice, I have beefed the original anaemic bar, with two 15x3mm cooper bar, and bras bolts.
Does look pretty cool and will be a good differentiator for Jerba. Be interesting to see a final version.This looks interesting Seatbase Jerba fans /
Nice to see there is still a bit of space in there if not much, I've got a slight challenge ahead as with some slight modification i need to fit in there....View attachment 144668
Final install of system under the seat base with the 200A Roamer battery, All sorted now , but it is a tight squeeze under the seat to fit in a new fuse box, shunt, bus bar, isolator and existing vehicle wiring.
Well spotted, yes is intentional. The single buss bar is only 45mm2, so having two paths makes it 90mm2, that feeds a 70mm2 inverter cable. Inside the inverter at the point of entry is a 150a mega. It’s the only way I could configure the box with all the connections in a small space. A bigger bodies not fit, as I was going for a linx box.Just a question on this bit, it looks like you have installed a copper bus bar on both sides of the top connectors down to the distribution bus bars.
Doesn’t this make the 250A fuse redundant? Or am I misunderstanding the picture?
Yep, well done @Fishd 10 T6F points for spotting the setup. i did ask @Raul a/3 about the pic (as it was public and might confuse some ppl) - but he knows his setup and its installed safely. - Hes using the block and fuse as a POS BusBar to pass some big power out to his large inverter which is why the fuse is bypassed, but adds material and weight to the connection to lessen heat build up.Well spotted, yes is intentional. The single buss bar is only 45mm2, so having two paths makes it 90mm2, that feeds a 70mm2 inverter cable. Inside the inverter at the point of entry is a 150a mega. It’s the only way I could configure the box with all the connections in a small space. A bigger bodies not fit, as I was going for a linx box.
Dellmassive spotted this first, and we was thinking, how long before anyone else mentions it. Good eye to detail you have.
Its a crude solution atm but what I currently have is a utilisation of the wasted space between the rear of the drivers seatbase and the kitchen units.Really liking the idea of this... now trying to work out how to shoehorn all the electrical kit I have into the drivers side seatbase.
Mk1 of similar for me was thisIts a crude solution atm but what I currently have is a utilisation of the wasted space between the rear of the drivers seatbase and the kitchen units.
@damo1023 what are you doing with this one ?
It will be coming out besides that fate undetermined. Happy to pass it onto someone for beer tokens/ kidneys / Black Market goods@damo1023 what are you doing with this one ?
Let me know when mate....happy to oblige with a donation of some kind......prefer to hang onto my kidneys though lolIt will be coming out besides that fate undetermined. Happy to pass it onto someone for beer tokens/ kidneys / Black Market goods
