Yes but if they are purely MQB they won't work with T5.1/T6.I just was reading a comparison about the Side Assists, and someone said that the 3Q0907566E 3Q0907590E (Bosch MRR-Rear) from MQB-Touran are better than the 5Q0
I am not sure about address CF, have to check it out.They appear as 2 real Canbus Devices.
Does PQ25 Gateway Support Address CF ?
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 E HW: 3Q0 907 566
Component: MRR1Rear H20 0510
Coding: 44C002
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 E HW: 3Q0 907 590
Coding: 44C002
By the way, what is the main advantage of 3Q0 over 5Q0?I just was reading a comparison about the Side Assists, and someone said that the 3Q0907566E 3Q0907590E (Bosch MRR-Rear) from MQB-Touran are better than the 5Q0
And the obvious question is, where is 7E0 on that list ?Dont know.
The 3Q0 is a MRR Sensor from Bosch, the same as the ACC Radar in Front.
It looks like this is a newer Generation.
And someone compared the following Sensors:
1. Place 3Q0907566E (Bosch MRR-Rear) ==> Best
2. Place 2Q0907686B (Hella RS4) ==> not so good
3. Place 5Q0907686B (Hella BSD3) ==> Bad
7E0 is a second generation system which requires ODIS calibration and VW calls it "Side Assist" system.I only can tell you that the 7E0 is a Model: LCA 2.0
Don't know what this means.
Verstanden .It is in german, but still a good info page from Hella.
Verstanden .
Seems that the original T6 Gateway does not support "CF".They appear as 2 real Canbus Devices.
Coding: 44C002
Coding: 44C002
Coding needed is 0x50.
To enable Bidirectional ABS Sensors @ the rear axis ABS Coding last Byte needs to be changed from 0x00 to 0x50 or to 0xF0 that is not Clear.
When enabling Bidirectional Sensors with Coding last Byte of ABS Coding to 0x50 or 0xF0 i get the Error:
Changed coding for the left Side to Bidirectional ABS Sensor (Last Byte 0x10)
Works like expected
Can you please tell me which Bit and Byte (in 03 Brakes?) exactly have to be changed? I only habe Obdeleven and there is no way to change something to 0x50
Your current coding for Byte 18 is 0x00.Great thank you!
Can somebody please make a Screenshot of Byte 18 with Coding 0x50 in VCDS so I can hopefully see what there is to be done in Obdeleven
