hi guys,
someone have the VW part number for the plug of the indicator ?
picture for exemple (not from T6)
Pretty sure the T5.1 platform doesn't support Side Assist, which is probably why it's showing the error "New feature! Extended UDS fault detail is only supported by current gen. interfaces"Hello everyone, I need your help, I am a t5.1 owner, I am trying to do Retrofit side assist, I have a problem that I can't solve, can someone help? Please
I would try by changing byte 0 from "02" to "03" (in 3C: Lane Change). Thus full coding "02032202" ==> "03032202"Hello everyone, I need your help, I am a t5.1 owner, I am trying to do Retrofit side assist, I have a problem that I can't solve, can someone help? Please
Looks like it has been done:do you think it would be possible to reflash it?
I haven't used that tool so I'm afraid I can't helpI tried to flash but I can't, I don't know where I'm making a mistake
ThanksLooks like it has been done:
View attachment 268521GOLF MK7 ACC Retrofit
Hi! I have problem, In module 13: Auto Dist. Reg. I have the camera unchecked. When I check it, 10 errors appear regarding the Databus. I am adding an auto-scan. Could this be caused by the camera not matching radar? Can replacing the radar with a newer one fix these errors? VIN...forums.ross-tech.com
As well as in these:
Distance
Hello, on Superb MY 2016 I changed standard instrument cluster with digital one (and also changed navigation screen and upgraded navigation head MIB head unit). Everything works OK, only radar distance picture on digital instrument cluster doesn't show car distance any more but always shows...forums.ross-tech.com
Golf 7 swapped AID for analog.. MOST problem..
The R cluster is back in and AID is out, wife liked it better with analog clocks.. But I cannot find the solution for this MOST/optical dtc on 5F.. MOST "cables" have been removed and the Dynaudio is working just fine :) Tried every AID retrofit guide backwards, but still not able to remove this...forums.ross-tech.com
GOLF MK7.5 : Big issues with MIB 3 & CAN
Hi Pals ! I own a Golf MK7.5 (2018) "Sound" 1.6 TDI 115HP DSG7. I'm that close to lpark my car near the riots in France and hope they burn it down Two years ago, I did some retrofits, not at the same time, added them one by one during the months that followed the first installation. -...forums.ross-tech.com
Skoda Kodiaq MY17, auto-hold connection to driver profile
My Kodiaq has three keys and three different driver profiles attached to those keys. This is nice, since almost every setting is connected to profiles, no need to do manual adjustments to mirrors, seats etc. Except for one thing. Auto-hold does not seem to remember it's setting. If you leave it...forums.ross-tech.com
2013 Seat Leon 5DR 1.2 TSI DSG Style (MQB) maps
Initial scan without any modifications to the hardware. Wednesday,31,May,2017,19:56:23:18632 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86 VCDS Version: 17.1.3.0 Data version: 20170320 DS267.7 www.Ross-Tech.com Dealer/Shop Name: Chop shop Workshop Code: 123 12345 012345...forums.ross-tech.com
BCM and GTW upgrade - problem with window heating and generator charge
hellou everyone, i retrofited my car fully, now i upgraded ambiente door color via lin... car: skoda octavia RS 2015/05 TSI 162KW i have problem after ugrade my BCM 5Q0937084CQ(0253SW) to DH(0312) no work correctly window heating front and rear, heating button blinking.. i see in gtw, generator...forums.ross-tech.com
T5.1 support side assist (if you mean T5.1 = facelift / GP)Pretty sure the T5.1 platform doesn't support Side Assist, which is probably why it's showing the error "New feature! Extended UDS fault detail is only supported by current gen. interfaces"
try vehicle status 36x golf
