Well, you can start with make and model.my car ......hmm.....from genuine is only chassias and VIN left, all equipmets , engine, dsg, brakes, interior, ... is from 2013 -2016
so not sure how to describe it
1K0937087AN - this is from Skoda SuperB , because only support Xenon with "analog" shutterThank you, make and model would do.
And what is your current BCM & CAN Gateway?
Thanks again.1K0937087AN - this is from Skoda SuperB , because only support Xenon with "analog" shutter
7N0035730BR
My friend says that it commes from the back extra Speaker of the ParkDistanceControl@dnoermann would you mind to check with your friend which module is the actual source of RTA audio warning on his retrofit?
Is it Instrument Cluster buzzer, PDC buzzer or maybe vehicle audio system speakers?
RCTA retrofit on a PQ35 vehicle is fairly simple. I am still waiting for your presentation of this system on your own T6.1K0937087AN - this is from Skoda SuperB , because only support Xenon with "analog" shutter
7N0035730BR
I have managed to verify thisAnd just to add to the above, the RTA system remains active until vehicle starts moving forward.
I am not sure if this is the result of having bidirectional rear sensors or simply system knows that vehicle is starting to gain speed while reversing gear is not engaged.
2005 1T1 Touran , Engine CFGC from scirocco, Kessy system from Scirocco , DSG from passat B7, leather seats from 1T3 Cross touran, wing mirros , cluster from Sharan , Brakes ABS + calipers from Scirocco, ACC radar from B7, RCTA from Sharan, MFSW from Sharan,
7N0035730BR
Don't bother posting,Thanks again.
You wouldn't dare to post your complete unedited VCDS Autoscan, would you?
Discover Media on T6 is a PQ35 unit which makes it 100% compatible with 5Q0 radars(they can be configured to operate as PQ35).
( credit to @mmi for supplying the screenshot)
But to display the actual visual RTA warning, the PDC unit has to be upgraded.
There are 2 choices:
1. 1K8 919 472 C
PROS: straight fit with adapter
Or repining
CONS: much more expensive
2. 5Q0 919 294 K
PROS: much cheaper
CONS: requires reflashing with 1K8 919 472 C firmware
EDIT:
Obviously same loom and same repining as above applies![]()
Hello,
I Just buy my T6 with Sat nav, front assist, ACC, etc... (For me it's Discover Media)
And would like to do the front PDC retrofit because I have just Rear PDC but, for me I have PQ25 Unit :
So is it possible to put the 1K8 919 472 C PDC module as you they to have better fonctionnality ? Or it will change nothing and need to upgrade to PQ35 ?
Others question, still no possibility to add Side Assist with Rear double doors ?
Cheers,
Flavien
Only P&P with =rear hatch , once you have barn door not easy,.
Side assistance module is place under lights ,
I made in my with barn doors, I mounted it lower...... under bumper on site tow hitch
still need pull wires , but look good
1. 1K8 919 472 C
Or repining
2. 5Q0 919 294 K
PROS: much cheaper
EDIT:
Obviously same loom and same repining as above applies.
