Thank you so much, I manually converted it to ODIS format, uploaded to the module, and all is working after changing some adaptations in the Discover MediaHere, xml for usage with vcp.
Attached xml in ODIS-E format if anyone else needs it
Hello again
I have finally fitted the sensors with the new PDC, still need to upgrade the ABS to T6
I was won how the change the animated view to look like this
Address 03: ABS Brakes Labels: 7E0-907-37x-MK100ESC.clb
Control Module Part Number: 7E0 907 379 Q HW: 7E0 907 379 N
Component and/or Version: ESC H06 0133
Software Coding: 347E4098256286832C7C0276A48B619328F550
Work Shop Code: WSC 00001 001 00001
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001 (VN75)
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 40D943B05A0C731BCF3-8014
4 Faults Found:
0055 - Front Right Wheel Speed Sensor
C101B 4A [137] - Incorrect component(s) installed
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 24
Mileage: 312337 km
Date: 2044.14.26
Time: 18:49:30
Address 3C: Lane Change Labels: 5Q0-907-686.clb
Control Module Part Number: 5Q0 907 686 C HW: 5Q0 907 686 C
Component and/or Version: HRE_Master H12 0080
Software Coding: 02031102
Work Shop Code: WSC 09003 957 00200
ASAM Dataset: EV_HREntryHella 001028 (VN75)
ROD: EV_HREntryHella_VW37.rod*
VCID: 3D2730DE2DF32E338C4-8068
2 Faults Found:
336901 - Databus
U1121 00 [009] - Missing Message
[Braking ECU ESP_33 - no signal/no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 43
Mileage: 241866 km
Date: 2053.14.16
Time: 23:51:21
338048 - Databus
U1123 00 [009] - Received Error Message
[Parkhilfe_01::PH_Tongeber_H_verfuegbar]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 43
Mileage: 241866 km
Date: 2053.14.16
Time: 23:51:21
On standard T6 byte 0 = 03 clears those faults.Software Coding: 02031102
Thursday,02,September,2021,09:02:14:10253
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.1 HEX-V2 CB: 0.4555.4
Data version: 20210824 DS330.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544 License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 37 3C 5F 65 77 0B
VIN: WV1ZZZ7HZDH036544 Mileage: 242830km-150887miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAAA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GF HW: 03L 907 309 M
Component: R4 2,0L EDC H44 3312
Revision: 26H44--- Serial number: 00000000000000 CVN: 7F3BF3CC
Coding: 01114012232400080000
Shop #: WSC 02736 790 50316
ASAM Dataset: EV_ECM20TDI01103L906019GF 003002
ROD: EV_ECM20TDI01103L906019FG_003.rod
VCID: 75B7E8FE5543B673844-8020
VINID: 9E606AAAA1D8A946000C6144105E5FB8A3
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 508724AD89A70A9B24A79175796210
Shop #: WSC 02736 790 49152
VCID: 3A2D3BC23C5D190BA96-806E
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 11031913470358
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F7D26075F52BD5E-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BM HW: 7E5 907 047 BM
Component: Climatic-T5 H20 0505
Revision: 00001010
Coding: 0000000002
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 7BA3FEC67367E003F20-802E
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 E HW: 7E0 937 090 E
Component: BCM PQ25 Max4 H84 0772
Revision: B9084001 Serial number: 2502 306190145
Coding: A8A0393E4E21201201280ED06EAB9ED4F08063FF608C2040320400030800
Shop #: WSC 12345 123 12345
VCID: 2D07009EFD13BEB33C4-8078
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 230916 03 37 0059
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 HW: 7E0 959 801 Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3313
Serial number: --------------------
Coding: 000000
Subsystem 3 - Part No SW: 7E0 959 802 HW: 7E0 959 802 Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3313
Coding: 000000
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39331623512708
Coding: 0031151001
Shop #: WSC 00020 999 12345
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: EV_EPHVA18VW364GP00_VW32.rod
VCID: 372B22F60FCF0463568-8062
1 Fault Found:
12718592 - Databus
[Steuerger‰t f¸r Lenks‰ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 242836 km
Date: 2021.09.02
Time: 19:00:05
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag003 H07 0013
Revision: -------- Serial number: 003HL00DDD0.
Coding: 000000000000000000000000000000003033
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 353728FE15C3F673444-8060
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 N HW: 7E0 920 970 N
Component: KOMBI H04 0805
Coding: 160A01
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 E
Component: GW-K-CAN TP20 H84 0772
Revision: B9084001
Coding: 042204
VCID: 6889B18A12715B9B0F2-803C
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 F HW: 7E0 857 511 C
Component: FLA H10 0003
Revision: AA001001
Coding: 010100E200000100000000
ASAM Dataset: EV_HighBeamAssisAU316 001004
ROD: EV_HighBeamAssisAU316.rod
VCID: 2D07009EFD93BEB33C4-8078
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0805
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DCB820CFD698B196-803E
Address 37: Navigation
Cannot be reached
2 Faults Found:
336901 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 43
Mileage: 241866 km
Date: 2053.14.16
Time: 23:51:21
338048 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 43
Mileage: 241866 km
Date: 2053.14.16
Time: 23:51:21
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 G HW: 5C0 035 680 G
Component: MU-S-ND-ER H41 0478
Serial number: VWZAZ2U1668085
Coding: 0645000FBE00000011112601010D08001F0303D401200100CE
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 2517F8BEA56386F3F44-8070
Data carrier:
Subsystem 1 - Part No SW: 5NA 919 866 AL HW: -----------
Component: MRM1 2020/21 --- 1420
3 Faults Found:
1602 - Data Set Implausible
B2012 00 [009] - -
[Control module (data record download) - implausible data record for DAB frequency tables]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 242836 km
Date: 2021.09.02
Time: 19:00:05
Voltage terminal 30: 13.7 V
15360768 - Component Protection
U1101 00 [009] - Active
[Anti-theft protection - component protection active (0xEA6300)]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 59
Mileage: 242836 km
Date: 2021.09.02
Time: 19:00:05
6720 - Rear View Camera
B1102 31 [009] - No Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 242836 km
Date: 2021.09.02
Time: 19:00:44
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 30000000047437
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 01:29, VBatt start/end: 13.8V/13.8V)-----------
Attached a VW37 experimental ROD file (not PDF). Place it in the folder C:\Ross-Tech\VCDS\Labels\UserAny suggestions welcome!
Because of the faults.It went greyed out as soon as I tried to tick it,
Thank you very much - VCDS is now working with it.Attached a VW37 experimental ROD file (not PDF). Place it in the folder C:\Ross-Tech\VCDS\Labels\User
Can you please post a auto-scan with vcdsThank you very much - VCDS is now working with it.
Just need to wait until freedom day (Monday) to hopefully get calibration done.
Of course - I will get it in the morning.Can you please post a auto-scan with vcds
Did you try: 03031102 ?Software Coding: 02031102
yes this will add another faultDid you try: 03031102 ?
Interesting - what fault was added?yes this will add another fault
