(Side Assist) / (Blind Spot Detection & Rear Cross Traffic Alert) retrofit
Hello everyone, I need your help, I am a t5.1 owner, I am trying to do Retrofit side assist, I have a problem that I can't solve, can someone help? Please
Pretty sure the T5.1 platform doesn't support Side Assist, which is probably why it's showing the error "New feature! Extended UDS fault detail is only supported by current gen. interfaces"
I would try by changing byte 0 from "02" to "03" (in 3C: Lane Change). Thus full coding "02032202" ==> "03032202"
Because I'm afraid the ABS you've got does not support brake intervention intiated by 3C (as now defined by byte 0).
Hi, Unfortunately I am not able to change this, I do not accept coding
Not accepted, or not shown??
Even though it's not documented in the pull down menu - just type in the "03" in the entry box, or full code "03032202" onto the top line.
Could also click on "LCode2" to show all the tickboxes.
Possibly you then need the "C"-revision of the radar - it's been used succesfully for this retrofit.
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
do you think it would be possible to reflash it?
Looks like it has been done:
As well as in these:
I tried to flash but I can't, I don't know where I'm making a mistake
I haven't used that tool so I'm afraid I can't help
Ok
T5.1 support side assist (if you mean T5.1 = facelift / GP)
I have owned a T5.1 multivan Edition 25 with factory side assist few years ago
What is the current state of affair for T6 2019 after upgrading to 1K8919472C from 7E0 919 475 AA. Is error message related to the lack of connection to the steering wheel control unit to be expected?
Hello I have a Volkswagen sharan from 2016 and would like to install the blind spot I found the cables, the mirror glass and the sensor I know where to plug them but I don't know how with the VCDS activated them
Can you help me by giving me a detailed list of what to do once installed since I see that on your T6 you have installed a 5Q sensor?
