That’s the new and expensive one. Good if you want the best. Cheaper option is the Orion 12 12 18 isolated:Victron Orion XS 12/12-50A DC-DC Battery Charger (700W)
Victron's latest DC-DC converter, with additional adaptive charging capabilities. Suitable for stepping down 12V to 12V at a maximum output of 50Amidsummerenergy.co.uk
Is this the correct one?
How would I house in drivers seat base? Need drilling through?
What wire would I need?
Many thanks,
I’ve made a pact with myself (with your kid support) if I can sort the DRL bodge myself and save £££, I will throw that at Dc to Dc and Ablemail
Seems fair![]()
The one I showed above from Amazon does both.If you are buying crimpers make sure they come with jaws for both heat shrink (DRL) and normal (Ablemail) crimps as the shapes required are slight different
Bought for solar install that was a similar hand hold job
I have these, would they suffice?
Oh and I do have these, purely for cutting and stripping, they'll strip 10mm² at a push.
That looks a good set. I had to buy another couple to cover other connectors.This is the set I have, comes with 5 different jaw sets for insulated, uninsulated, ferrules etc.
OrderedThis is the set I have, comes with 5 different jaw sets for insulated, uninsulated, ferrules etc.
