Shopping list looks good. You don’t need switches but can be useful for managing the system and/or for maintenance. One in the cable between the Orion Pos Out and AMT Leisure Pos allows you to turn the AMT on/off - needs to be >3A capable.can someone drop a link to whatever fuse and switch I would need please?
I am currently curating a basket at simplysplitcharge website (Ablemail/ wiring currently).
Bw
Chris
I'd get something similar to this:![]()
12V 24V ON Off Push Button Switch Surface Mount Switch Rocker Switch Paste-Type | eBay
[ON-OFF Push Button Switch]: Push ON / Push OFF. [Double-Sided Tape]: Strong double-sided tape for paste-type installation. [Pre-wired Cable]: 0.5M red + black prewired for trouble-free installation.www.ebay.co.uk
Would this work for the two switches?
Why did you want a switch to stop leisure battery being charged when engine started?
Is it a midi fuse holder I would need?
That's not a VW SCR then, Amber Valley will be an aftermarket SCR.
That’s for the diesel heaterThat's not a VW SCR then, Amber Valley will be an aftermarket SCR.
Is that a heater vent pipe alongside the battery?
Does this change things?That's not a VW SCR then, Amber Valley will be an aftermarket SCR.
They would be ok if you want to surface mount under the seat. Or the ones I linked if you want them accessible on the back of the seat base (20mm hole and push fit).![]()
@roadtripper you have me twitched…. Hovering over purchase button but holding until someone can confirm the amber valley doesn’t torpedo the planDoes this change things?
Many thanks, really need to be sure before I start ‘f***ing’ stuff up!Sorry, I have no direct experience with that but I don’t see why it would change things. As long as it has a feed from the SB and a feed to the LB then it’s no different. Just check cables and fuses are suitably sized. I can have a closer look at the pics this eve.
Thank you. I’ll get some better pics when I take seat out.Yeah it might be wired up a little differently but it's all the same principle.
