(Solved) Van won't start after work on the wiring under the passenger seat.
Here is all the information from a VCDS scan:
Code:
Friday,28,July,2023,15:04:54:49617
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WV1ZZZ7HZHH145893   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 5F 61 69 0B
VIN: WV1ZZZ7HZHH145893   Mileage: 211410km-131364miles
02-Auto Trans -- Status: OK 0000
15-Airbags -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXHA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KG    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 3771
   Revision: 23002001
   Coding: 00254014431501090000
   Shop #: WSC 50234 002 1048576
   ASAM Dataset: EV_ECM20TDI03004L906056KG 004004
   ROD: EV_ECM20TDI03004L906056KE_004.rod
   VCID: 7CA1E61C26677AFA533-8028
   VINID: 9E606AAAA1D8A986011052090C6B331798
6 Faults Found:
31103 - SCR NOx Catalyst Bank 1
          P20EE 00 [096] - Efficiency too Low
16230 - Control Module for Instrument Cluster
          U1019 00 [032] - Missing Signal for Oil Level/Temperature
          [Instrument cluster control moduleMissing signal oil level/temperature]
27202 - Sensor Reference Voltage A
          P0641 00 [032] - Open Circuit
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 211265 km
                    Date: 2069.01.12
                    Time: 13:03:01
                    Engine RPM: 47.50 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 20 °C
                    Intake air temperature: 16 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 4.296 V
                    Unlearning counter according OBD: 34
                    Engine status: Engine start
                    Engine running time-Pressure BIN10 bar: 0 s
                    Control Module temperature: 25.2 °C
                    ESM_Battery_voltage-Voltage: 4.32 V
                    Low battery mode active-Bool type: No
                    ESM_Vext_raw-ESM_sensor_voltage: 3.2891 V
                    Starter control: terminal 50 feedback-Terminal 50 on CAN: active
                    Starter control: terminal 50 feedback-Terminal 50 CAN valid: active
                    Starter control: terminal 50 feedback-Terminal 50 via cable: active
                    Starter control: terminal 50 feedback-Starter relay: active
                    Starter control: terminal 50 feedback-Starter operation read back wire T50Ret: active
                    Starter control: terminal 50 feedback: 62
                    Starter control: shut-off conditions 1-Immobilizer: not active
                    Starter control: shut-off conditions 1-Starter shift malfunction: not active
                    Starter control: shut-off conditions 1-Speed: not active
                    Starter control: shut-off conditions 1-Drivetrain: not active
                    Starter control: shut-off conditions 1-RPM aborted starts: not active
                    Starter control: shut-off conditions 1-Engag. duration: not active
                    Starter control: shut-off conditions 1-Engag. duration aborted starts: not active
                    Starter control: shut-off conditions 1-Engag. duration panic start: not active
                    Starter control: shut-off conditions 1-new errors: not active
                    Starter control: shut-off conditions 1-manual start/error: not active
                    Starter control: shut-off conditions 1-ignition: not active
                    Starter control: shut-off conditions 1-Clutch error/terminal 50 malfunction: not active
                    Starter control: shut-off conditions 1-Direct start function: not active
                    Starter control: shut-off conditions 1-Engag. duration defrost.: not active
                    Starter control: shut-off conditions 1: 0
27200 - Sensor Reference Voltage B
          P0651 00 [032] - Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 211265 km
                    Date: 2069.01.12
                    Time: 13:03:01
27198 - Sensor Reference Voltage C
          P0697 00 [032] - Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 211265 km
                    Date: 2069.01.12
                    Time: 13:03:01
                    Engine RPM: 95.25 /min
                    Voltage terminal 30: 5.515 V
                    ESM_Battery_voltage-Voltage: 5.22 V
27196 - Sensor Reference Voltage "D"
          P06A3 00 [032] - Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 211265 km
                    Date: 2069.01.12
                    Time: 13:03:01
Readiness: N/A
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0BT 300 046 J    HW: 0BH 927 711 G
   Component: DSG DQ500-7F  H11 5301
   Revision: 00H11V01    CVN: A5BFDF55
   Coding: 0014
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021_001_VW36.rod
   VCID: 3D272B187DFDB3F224D-8068
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 40727000000388
   Coding: 517E4098256684838A7D027FA48521E6790000
   Shop #: WSC 02739 790 50316
   VCID: 3FDB511077F1A1E2361-806A
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 03031713471417
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5EC14307B68EA7D7-802A
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E0 907 047 AK    HW: 7E0 907 047 AK
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ClimaticT5 A01003
   ROD: EV_ClimaT5Basis.rod
   VCID: 73B3CD200B393582029-8026
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 069170760
   Coding: A0AC393A0A613411802849742C2B8C548F10710F60464D60320400230800
   Shop #: WSC 02737 022 2044595
   VCID: 2A0D10449CF3344A71F-807E
   Subsystem 1 - Part No SW: 7E0 959 801 Q    HW: 7E0 959 801 Q  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU001031770604278
   Coding: 1400B1
   Subsystem 2 - Part No SW: 7E0 959 802 Q    HW: 7E0 959 802 Q  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU001031770604849
   Coding: 0400A1
   Subsystem 3 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
   Coding: 000000
   Subsystem 4 - Part No SW: 2H0 959 442     HW: 2H0 959 442
   Component: E221__MFL-DC1  H02 0103
   Serial number: 46170000637210127095
   Coding: A4FFFF
4 Faults Found:
01758 - Bulbs for Brake Lamps
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 93
                    Time Indication: 0
00329 - Control Circuit for Unlocking Rear Lid
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 87
                    Mileage: 211265 km
                    Time Indication: 0
                    Date: 2017.11.30
                    Time: 17:42:52
03301 - Response Closing Status of Drivers Door
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 211417 km
                    Time Indication: 0
                    Date: 2017.12.18
                    Time: 00:08:52
03303 - Response Closing Status of Rear Left Door
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 49
                    Reset counter: 93
                    Mileage: 209997 km
                    Time Indication: 0
                    Date: 2017.07.19
                    Time: 11:33:12
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag01T H08 0018
   Revision: --------    Serial number: 003V30047AFU Dataset Number: 7E0003V____ 0881
   Coding: 000000000000000000000000000000003154
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3A2D20046CD384CA01F-806E
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Component: KOMBI         H03 1104
   Serial number: 00000000000000
   Coding: 440B010300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 042305
   VCID: 6889AA4C427FC65AA7B-803C
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 1104
   Serial number:
   Coding: 000000
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6A8DD0445CF3F44AB1F-803E
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
   Component: MU-E-D-ER     055 7085
   Serial number: 21021700011435 Dataset Number: V03935253YT 0001
   Coding: 065700003C00000041111101008000001F0000C60000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001032
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2E051C54A09B586AAD7-807A
2 Faults Found:
1564 - Microphone 1
          B129B 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 53
                    Mileage: 211417 km
                    Date: 2023.07.28
                    Time: 20:50:09
                    Voltage terminal 30: 12.1 V
0011 - Digital Radio Antenna
          B1103 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 23
                    Mileage: 209997 km
                    Date: 2023.02.26
                    Time: 11:29:12
                    Voltage terminal 30: 14.0 V
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H81 0744
   Coding: 330B1A73
   Shop #: WSC 80093 222 69422
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Component: J367-BDMConti  H03 1050
   Serial number: 758857000017030303E0
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000433558251
   Coding: 410D000103000000
   VCID: 323D0824B4237C8AC9F-8066
2 Faults Found:
02564 - Trailer; Left Tail Lamps (M60)
            010 - Open or Short to Plus - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 210612 km
                    Time Indication: 0
                    Date: 2017.07.22
                    Time: 10:29:47
00532 - Supply Voltage B+
            011 - Open Circuit - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 87
                    Mileage: 211265 km
                    Time Indication: 0
                    Date: 2017.11.29
                    Time: 17:28:33
End----(Elapsed Time: 01:29, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
I haven't done anything apart from a scan so far as I didn't just want to clear the codes without knowing what I'm doing as this is the first time I have used VCDS.
You have that scan saved now so you can clear all codes, then try start the van and then run a new scan and share it here.
I am not au fait with vcds logs but the last line would make me charge the vehicle battery up fully first.
"End----(Elapsed Time: 01:29, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----"
I don't know if this is historical data but I charged the battery yesterday, Just running another scan now
Code:
Friday,28,July,2023,15:50:32:49617
www.Ross-Tech.com
01-Engine -- Status: OK 0000
69-Trailer -- Status: OK 0000
   Revision: 23002001
Readiness: N/A
   Coding: 0014
   Coding: 01
   Revision: 00001002
   Coding: 0000000003
   Coding: 1400B1
   Coding: 0400A1
   Coding: 000000
   Coding: A4FFFF
   Coding: 440B010300
   Revision: B9081001
   Coding: 042305
   Serial number:
   Coding: 000000
3 Faults Found:
0001 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 53
                    Mileage: 211417 km
                    Date: 2023.07.28
                    Time: 22:58:16
                    Voltage terminal 30: 11.6 V
1564 - Microphone 1
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 53
                    Mileage: 211417 km
                    Date: 2023.07.28
                    Time: 22:58:16
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 53
                    Mileage: 211417 km
                    Date: 2023.07.28
                    Time: 22:58:16
   Coding: 330B1A73
End----(Elapsed Time: 01:22, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
The following VCDS measurements might give some initial ideas
VCDS > Select Control Module > 01-Engine > Adv.Meas.Values > Tick the following
IDE00018 Voltage terminal 15​
IDE00019 Voltage terminal 30​
IDE00020 Terminal 15 status​
IDE00412 Starter control: terminal 50​
IDE00413 Starter control: Interlock- or P/N-signal​
IDE00416 Starter control: terminal 50 feedback​
Please check the above in key positions
(A) IGNition on​
(B) Start​
Is terminal 50 alive - any activity when key in start position?
(A) IGNition on​
(B) Start​
Thanks, I think the battery must be fooked as it is now showing just 8v, I charged it fully yesterday, so nothing at terminal 50, I'm going to get a new battery in the morning and try again.
That resting battery voltage does seem rather low and if you fully charged it and its gone that flat that quick then its pretty safe to say its pooped
Low battery voltages can do all sorts of weird and wonderful things to the electrical system so nothing else you can do, will be interesting to see what happens with a new batt installed
If you still get a non start situation with a new battery installed (make sure its charged) then the measurements @mmi suggested above would be a good place to start
Cheers mate, I'm also going to give all the connections to the battery a good clean as they look a bit corroded, you would have thought that with it being an RAC van they would have put a bit of grease on it.:laugh:
Could it be a transponder/key issue, is there a way to check this in VCDS?
Not likely - it wouldn't prevent engine cranking/starting but would shut off engine in a few seconds.
Anyways, to check the keys/transponders
VCDS > Select Control Module > 25-Immobilizer > Adv.Meas.Values > Tick e.g. the following
ENG109584 Transponder ID of 1st key​
ENG109585 Transponder ID of 2nd key​
ENG109586 Transponder ID of 3rd key​
ENG109587 Transponder ID of 4th key​
ENG109592 Transponder ID of current key​
EDIT:​
If the current key ID matches one of the registered keys it is good to go.​
EDIT:​
They match so that is one less thing.
Maybe this has been mentioned and I have missed it.
Can you use one jump cable, clamp one end on the engine block(or any exposed engine solid piece of metal) and the other end on battery negative terminal?
And then attempt to crank your engine.
To check the earth to the engine, I will try that now thanks.
I have ordered a new battery as this one seems to be draining anyway, I charged it overnight to get the following readings from when the key is turned from ON to START.
Address 01: Engine (04L 906 056 KG)
14:03:38
IDE00018 Voltage terminal 15 11.986 V
IDE00019 Voltage terminal 30 11.907 V
IDE00020 Terminal 15 status On
IDE00412 Starter control: terminal 50 not active
IDE00413 Starter control: Interlock- or P/N-signal active
IDE00416-MAS07386 Starter control: terminal 50 feedback-Terminal 50 on CAN not active
IDE00416-MAS09390 Starter control: terminal 50 feedback-Terminal 50 CAN valid active
IDE00416-MAS09391 Starter control: terminal 50 feedback-Terminal 50 via cable not active
IDE00416-MAS09392 Starter control: terminal 50 feedback-Starter relay not active
IDE00416-MAS09394 Starter control: terminal 50 feedback-Starter operation read back wire T50Ret not active
IDE00416 Starter control: terminal 50 feedback 8
