@Absolut5
Is the cost of the Kenwood amp & Audison uss4 worth it to drive the Eaton F2.1's and a set of Focal rears or are they ok on their own?
I know its probably subjective, but I'd rather take your expert advice than waste cash.
@Absolut5I say definitely a yes, the amp will drive the door woofers for greater depth. and it sounds cleaner.
im not a big fan of amping the rears , but this amp has front and rear gain so you can set it just right
Jason,
Is the above a plug & play fitment (installed behind the LHS of dash), if so can you quote a P&D for the above please?
Or is there now something better since I 1st asked nearly 2 years ago?
Info, if it helps...
I have a T6,, fitted with Eaton F2.1's in the doors & A pillars & a pair of 4" Focals in the rear.
Rear fader has been enabled through VCDS
