Hi Guys.
I hope you don't mind me jumping in as a new comer. This is a subject I know about I am a technical sales engineer for power products.
Please listen to the others that have advised not to use VSR's on euro 5 & 6 vehicles with smart alternators . By design the ecu will only charge the battery to 80% to allow for the regen braking to charge the vehicle battery under braking conditions (kinetic energy converted to electrical energy instead of heat in brake pads) 15v + will be present on any auxiliary battery and loads. Even with a Vsr that has over voltage protection the variable output from the alternator will not be suitable for charging a secondary battery.
Many manufacturers and installers are trying to use/adapt Vsr's, and relay systems to work with smart alternators but in reality this will never be a safe and efficient method.
We have heard of horror stories of euro 6 vehicles bursting into flames due to the mis-application of a Vsr into a van with a smart alternator.
A Dc-DC charger is really the only option, these work just like an Mppt controller and buck or boast the variable voltage to an optimum charging algorithm.
There are many choices on the market but i like the Redarc, an Australian manufacturer that has designed a superior Dc-DC charger
I appreciate that what use to be a £30 job is now £300 but the batteries and your safety will be better off.
I hope this helps
Hi Guys.
I hope this helps
Hi guys, I posted this elsewhere but I thought you might like to know that there are some dodgy converters out there who don't fully understand the Euro5 engined T6.@Rik. Although you have a Euro5 engine, like @T6 Dave, you do have Blue Motion Technology, Smart Alternator, Regenerative Braking and Stop Start technology that is common to the T6 model regardless of Euro5 or Euro6 engine. You need to be aware of this if you are getting a converter to lineout and carpet your van and fit a leisure (second) battery because you cannot use a split charge relay (VSR) and need a smart charger such as the Ring dc30 (there are other makes) because, as @T6 Dave has found, there are still converters that don't understand that the Euro5 T6 has the same electrical needs for smart b2b charging systems as the Euro6 version. Getting it wrong could result in an electrical fire.
Unfortunately there are a lot of scare stories and conflicting information on this subject. I am an electrical controls engineer and have based my installation on the evidence I have observed and the welcome insights of this forum. I have a verified voltmeter on the output of my main battery. In all driving conditions it has never been above 14.8v, and with lights on stays at that. If/when the alternator does reduce its output it drops to 13.4v if theres a light load like the fan on, or 13v if not.
I don't believe VW have built any sort of sophisticated charging circuit into the T6. Its either on or off. They fit AGM batteries as standard as they are more tolerant of this type of charging. Their second battery installation just uses a relay. VW would not fit a system if it was prone to blowing the ***s out of their customers expensive add-ons.
Based on the above, you could use a VSR, and a lot of people have done without a problem. It just won't charge your battery very well and if you use a standard lead-acid the battery probably won't last long. I have a Ctek 250s fitted, connected to the normal input with no ignition-fed relay. It works really well. I fitted it for the simple reason that I wanted to charge my leisure battery quickly and efficiently.
Of course this is just my opinion and may get some purists spluttering, but I'm more than happy to hear reasoning that might change my view. For instance, could someone explain what causes a VSR to burn out/ cause an electrical fire if fitted to a T6?
