Thank you, that’s a very kind offer.hi mate I have a spare 17steel wheel with a tyre just legal you can have foc pm if any good to you
Thinking about installing a switch somewhere/somehow onto top of the spare wheel fixing bolt - then wired in series/parallel with rear door open signal which then should trigger the alarm early.......and cars with a TPMS sensor inside the wheel only monitor at the 4 wheels and not the spare in the boot. . . . . as far as im aware.
So perhaps time to start another @Dellmassive "How i done it thread" - "Alarming spare wheel"??
Thats an interesting idea...
It will work fine
saw these, but would rather have something with a less generic key, its only a 3 pin bolt and key, easily undoable as much as a standard bolt.There is a lock that shrouds the bolt in the forum shop..
That is all you need, the scrotes use grips on the bolt. I'm not aware of any being stolen once they have fitted this on here or the California club forum.saw these, but would rather have something with a less generic key, its only a 3 pin bolt and key, easily undoable as much as a standard bolt.
Where I can get a spare 17" Davenport Alloy?
yep, was surprised when I looked underneath when I first got it. use to make sure it was cleaned with the pressure washer when I washed the car.Are you sure your spare was an alloy? Most spares are steel.
You can also add a bike lock through the wheel as well.
Also, carry a tyre string kit with you and you stand a good chance of plugging the hole without having to remove the old wheel.
